94-02 Moog Part Numbers
LOGANSTANFORTH
moog numbers:
94-02 2wd part numbers:
02-94 adjuster sleeve: ES2080S
99-94 adjuster sleeve: ES2080S
02-00 tierods: ES3540 outer right, ES3539 inner right,
ES3539 inner left, ES3540 outer left
99-94 tierods: ES3172RLT outer right, ES3171RLT inner right,
ES3171RLT inner left, ES3172RLT outer left
02-00 solid axle 3500 HD tierods:
PITMAN ARM TO RIGHT HAND STEERING ARM: right hand connecting tierod DS1460,
adjuster sleeve ES21012S, pitman arm tierod ES3527.
LEFT HAND STEERING ARM TO CONNECTING TIEROD: connecting tierod DS1462,
adjuster sleeve ES21012S, left tierod ES3526.
99-98 solid axle 3500 HD tierods:
PITMAN ARM TO RIGHT HAND STEERING ARM: right hand connecting tierod DS1459,
adjuster sleeve ES21012S, pitman arm tierod ES3497.
LEFT HAND STEERING ARM TO CONNECTING TIEROD: connecting tierod DS1456,
adjuster sleeve ES3498S, left tierod ES3496.
track bar: DS1413, replacement bushing: K7252
97-94 solid axle 3500 HD tierods:
PITMAN ARM TO RIGHT HAND STEERING ARM: right hand connecting tierod DS1309,
adjuster sleeve ES21012S, pitman arm tierod ES3249RT.
LEFT HAND STEERING ARM TO CONNECTING TIEROD: connecting tierod DS1308T,
adjuster sleeve ES21012S, left tierod ES3248RT.
track bar: DS1256 before 2/7/94, DS1413 after 2/7/94, replacement bushing K7252
99-94 solid axle 3500 HD REAR tracbar K7382
02-00 upper balljoint: K7366
99-94 upper balljoint: K7206T
01-00 lower balljoint: K7365
99-97 lower balljoint: K7269
96-94 lower balljoint: K7205T
99-94 upper control arm bushing kit: K7276(2 per truck)
99-94 lower control arm bushing kit: K7277
2WD STRAIGHT AXLE 3500HD:
02-00 upper balljoint: K7397
99-94 upper balljoint: K8388T(enhanced design)
02-00 lower balljoint: K7394
99-94 lower balljoint: K8607T(enhanced design)
99-94 upper control arm bushing kit: K7278(2 per truck)
02-94 swaybar link kit: K7275
99-98 3500 w/ straight ball stud swaybar link kit: K7300
99-96 3500 w/ tapered ball stud w/ solid axle swaybar link kit: K7280
97-94 3500 w/ straight ball stud w/ solid axle swaybar link kit: K7299
97-94 3500 w/ straight ball stud w/ solid axle swaybar link repair kit: K7300
***PM ME: for swaybar to frame bushing kits, too many to list***
02-00 2500 w/ 7500lb GVWR idler arm: K7347, pitman arm: K7345
99-95 2500 w/ 7500lb GVWR idler arm: K7217T(HD), pitman arm: K7239
99-95 2500 w/ 8800lb GVWR idler arm: K7225T(HD), pitman arm: K7238
02-00 3500 IFS idler arm: K7347, pitman arm: K7345
99-95 3500 IFS idler arm: K7225T(HD), pitman arm: K7238
1994 2500 w/ 8800lb GVWR idler arm 2nd design 16mm bolts: K7225T(HD), pitman arm: K7238
1994 2500 w/ 8800lb GVWR idler arm 1st design 14mm bolts: K7237, pitman arm: K7238
1994 3500 IFS idler arm 2nd design 16mm bolts: K7225T(HD), pitman arm: K7238
1994 3500 IFS idler arm 1st design 14mm bolts: K7237, pitman arm: K7238
94-02 4wd part numbers:
***ALL NUMBERS ARE FOR DANA 60 AXLE***
02-00 trackbar: DS1413
02-00 tierods:
99-98 trackbar: DS1413
99-98 HD tierods:
97-94 trackbar: DS1256 before 2/7/94, DS1413 after 2/7/94, replacement bushing K7252
02-00 pitman arm: K7339
RangerDanger
