88 Chevy 2500 6.9 IDI swap
hacked89
Bucks County PA
Yea, you can probably use an 85-96 ford 460 radiator. It’s 1.75 x 1.75 though so on the one side you’ll need to a non oem hose but this is a custom project I’m thinking you aren’t using oem hose anyway since it’s a Chevy core support.
u2slow
bilge rat
Coastal BC
Try the non-Ac IDI rad? It is wide and short.
There's also the 6.2 diesel and 454 rads.... Probably since 73 to 98 range. These were wide too.
Isaac Ristow
Somerset Wisconsin
The problem is the hose barb orientation is completely different on gm to ford/idi custom metal piping would probably have to be made which I've done stuff like that before maybe its feasible for him to do with this I've gone from 6.2 diesel to a ford idi radiator before was metal cross over pipes I made. But to OP I would definitely check with the short wide ford idi radiator iirc they are like 20 inches tall and 37 or 42 wide or something? My perkins swapped 85 c30 has a early bullnose 460 radiator in it it actually fit the gm core support very well slight modification but it's a square body.
u2slow
bilge rat
Coastal BC
Chevy rads didn't change a lot with the body style change.
Sounds like the 460 and short/wide IDI rad are similar. This configuration stays above the frame rails, but basically spans from headlight to headlight.
hacked89
Bucks County PA
The 460 and the non ac core supports are the same. The reason I told him 460 radiator and not “idi non ac” is because the 460 radiator is cheap and available and the non ac radiator is not available
FoxNotch
NYC
FoxNotch
NYC
Been chipping away at this in our very limited spare time.
Still not settled on a radiator. Due to the chevy steering box location and the IDI engine fan sticking down so far a drivers side lower radiator port would be really difficult to plumb. So current plan is to use a Chevy radiator that at least fits right, and plumb accordingly. Still shopping around for a radiator with correct port sizes.
Other than that, fuel system is plumbed, exhaust pieced together, shift linkage adapted, dipstick tubes bent to fit and driveshaft installed (DS from the van was a direct fit so that's nice).
Any ideas on where to find a wiring diagram for the Chevy? 88 c2500
FoxNotch
NYC
Going well, though working on it very rarely. Busy with other projects and other stuff keeps breaking.
Went with a late 90s chevy radiator/shroud. Which was obviously bolt up but had to make custom plumbing.
Otherwise just knocking around town with it and tinkering as we go. Straightening out what we need or don't need out of each wiring harness little by little.
Coolant, fuel level and voltage gauges are working well. Tried a few different senders for oil pressure but that's not responding. So may have to just go aftermarket there along with a speedometer.
Next big item is converting the front to 8 lug and going through the suspension and brakes.
