7.3L Fuel Filter Replacement
adrianspeeder
USAF C-17 Avionics
Dover AFB / Harrisburg PA
Subject truck: 2002 F250 Powerstroke with 27K miles.
Need:
Rags
Pan
Plastic water bottle
fliter
socket set
strap wrench/channel locks/filter cover removal tool
1. Remove powerstroke plastic "thingie"
2. Use a strap wrench or channelocks to twist off the plastic filter cover. I used the fancy bling bling filter cover removal tool from dieselinnovations ;Sweet
3. Pull out the filter and rubber o ring and put the whole mess into a pan.
Tip 27K is a little too long for the filter...
4. New Racor filter F4596 from dieselinnovations for 18.44
5. Slip new round O ring around the base of the filter just like the old one.
6. Drain water seperator by placing a bottle over the drain on the passenger side of block.
The bottle I used was a little too tall to fit, so I poked a hole in the side
7. Drain the water seperator by turning the yellow valve to the right, then CLOSE the valve when the bowl is empty.
8. Lube the oring on the filter with some diesel and place into bowl snugly.
9. Lube the filter cover with diesel and place around the top of the bowl
10. Retighten filter cover
11. Reinstall powerstroke plastic "thingie"
Adrianspeeder
colotow
I refuse to grow up
Tooele, utah
i got a tip from a ford mech, i put a short piece of rubber fuel hose over the end of the drain tube, clears everything and runs into a pan or bottle with no fuss at all
mojoman
Okanagan BC
Thank You AdrianSpeeder, is the 95 psd the same?
only difference I see is my '95 has a fuel filter cap that has a 1/2 inch ratchet adapter for removal...just use a short 1/2 inch ratchet extension and spin 'er off......hth
mojo
VanBoy
WA
The Wix filter I purchased for my 99 van HAD the cover with the filter. According to the dealer, the separate cover that Wix sold is no longer available. They're selling replacement filters w/ the lid now..... not sure if a seperate filter is available, as I didn't bother to look at the filter to see if the lid could be detached.
VanBoy
WA
The filter I received from the parts dealer, a Wix, already had the filter cover with it. I was told that the separate cover is no longer available as with the separate filter- the separate filter crossed over to the one w/ the lid enclosed. This is Wix at least, don't know about the other manufactures. I didn't bother to look at the cover to see if the filter was removable (I'm guessing it is).
This was a filter for my 99 E350.
DavidinKy
David
Ky
mojo
You probably already have an aftermarket filter. For one, Auto Zone sells a filter with the 1/2" drive socket. David
Sleeper7.3
Oxford Al
was just about to post asking how to do this ..good thing I choose to look around first thanks oh before I replace mine ..fuel is flowing out from under the filter I havent found where but i know its comeing from the filter area...any Ideas?
ntjapkes
