Goofyexponent
Mentally Unstable..
Today i left for work as usual. After I hauled a couple loads of hot asphalt to downtown Halifax, I decided to stop for a bite to eat at home. When I came in the parking lot I seen a HUGE fuel stain in the spot where I parked my pickup truck....when I got to the shop I discovered that the rear tank was leaking like a ***** . Not impressed...I had to use an O/A torch to gracefully remove the spare tire carrier. I did not remove the plate that goes inbetween the tank and tire yet, but I know I am going to find a rusty tank.
Will the rear tank from a 1992 - 1996 F150 gasser work? It will have to be cleaned out and whatnot, but will it work with my pickup and sending unit? I also found a 32 gallon tank from a bronco...I am not so sure on this one fitting though
