Trailered home a 1989 F350 dump truck that looks great on the outside, but the 7.3 IDI is something else
crazydane
Afton, VA
Called up CHI and they do have a set of rebuild heads in stock. They will accept a pair of the cracked ones as cores. $1,150 total, including shipping the cores back.
Just to get heads redone by Justin is $1200 just to put it in perspective
I still question how bad they are. Why would a shop accept cracked heads as a good core, unless its just the pre cups.
crazydane
Afton, VA
I'm swinging by the local machine shop tomorrow to pick up one set of the cracked heads. I'll see if he can point out where they are cracked and I'll take some pictures.
He also wants me to bring him the main caps and bolts so he can torque those to spec before boring the block.
The rebuild heads should be here Thursday. So hopefully I can finally start putting this thing back together again soon!
crazydane
Afton, VA
Picked up the cores.
Other head:
Crack is clear on the first head, but I don't really see it on the 2nd one, but I guess they did when magnafluxing it?
The one with the crack between the valves is unfortunate, but the other one... Send it out as a core I can't see anything either.
crazydane
Afton, VA
Good catch. Yep, its there.
Got the new heads in today. They look nice I think:
Precups have minor cracking, but nowhere near extending out to the fire ring:
Did I mention they also come with a 1 year warranty? All in all I think a very fair deal and they got from Texas to Virginia in 4 days from when I ordered them Monday. They went regular UPS ground. Poor UPS lady was struggling getting them off her truck, so I gave her a hand.
I put the core heads back in the boxes, attached the included return labels, and dropped then off at the UPS Store. Done.
The_Josh_Bear
Western WA
Wow I'm amazed that they delivered those on a normal UPS truck. And same thing that you could just walk in and return the old ones, I wouldn't have guessed that at all. Must be right at the upper limit. To send an average delivery driver out to wrestle 100lb cast iron is a little much...
They sure look nice! Hopefully they aren't shaved at all and have the right valve clearance. Amazing shipping speed, too.
crazydane
Afton, VA
Last time I spoke to the shop, they were still waiting on the pistons to come in. Going to check with them again early next week to see what the status is. He did show me the hot tanked blocked when I picked up the heads to return as cores. Looked really nice. Should have taken a picture or two.
crazydane
Afton, VA
Finally got the block back!
They unfortunately weren't able to get .020 pistons, only .040 ones, so that's what it got bored too. He assured me I won't have any issues going that much over. He did have me bring the cam shaft in so they could do a test fit before I left. It was a nice tight fit, but spun smoothly.
Total cost also ended up being more than the original estimate:
So grand total was just shy of $2,400. I'm sure them tearing down 4 heads only to find they were all cracked didn't help.
I'll see about getting the block unloaded and on a stand.
crazydane
Afton, VA
Got the block unloaded. Looks really nice:
New freeze plugs:
I'm not expert, but it looks like they used the correct tool to install them?
And one of the .040 over pistons:
Still a little bummed they took it to .040 over instead of .020 as was the original plan, but I guess if no .020 (or .030) are available anymore, that was the only option...
Rings came already installed on the pistons. So best practice would be to take them off and gap them for the bore they are going into, correct? If so, I'm wondering why they came already installed...
ntjapkes
