Tool Box Bed, trans, axles, other stuff
264WSM
Wyotana
Service Box on frame with dually kit Sterling axle. I was gonna make this a trailer and don't think that I will ever get to it. Cab goes with it or I can sell doors separately (rest of the cab is not worth trying to save). $800 as is. Doors - $75 complete each (crank windows). Pix coming soon
E4OD Auto trans from 7.3 4x4 with transfer case. Worked when parked. $350
C6 Auto trans from 6.9D. For 4x4. With transfer case. $200
Transfer case from ‘88 F-250 $100
Several F-250 axle sets. 1980’s, 3.55 and 4.10 gears $250/set
Set of 5, 8 hole factory rims $100
400cid gasser - stuck (I think the carb is missing) $60 you help pull
4spd trans from above engine. 2 WD. $75 you help pull
Whole brick nose F-350 SRW truck w/o title. Missing bed. $125 I'll load.
Cant Write
Placerville CO
Whats the last 3 digits on the 400 block? Trans is SM-465?
Sometimes I dream of simplicity and running 2 burbs, my 4x and a 2wd for 90% of the time. A 400/465/3.08 geared 2wd sounds about perfect.
mydixiewrecked
