Leaking Shower Head Return Line
IDIrty
Canada
I just “deleted” my rear fuel tank and FSV, as rear tank was rusty/leaking and FSV was stuck on rear tank. ***Edit: this is for 6.9 with metal fuel tanks, for reference***
Routed return/supply lines for front tank only and there are no leaks in lines… BUT on top of shower head where the lines are metal there is a leak (small hairline crack in return). Looks like someone had previously used some sort of rtv/puddy/etc to patch it but in process of disconnecting/reconnecting lines I messed it up.
I’m wondering what y’all think is best way to patch it again? I don’t really wanna buy a whole new sending unit. Permatex gasket maker, a fuel tank patch kit? What y’all thinking?
Thank you in advance!!
Clb
Another old truck
nannyfornia
Brass
I've never used jb weld in fuel before, pic of issue?
A leaking return inside of the tank seems no big deal....
Rdnck84_03
Kansas
Permatex makes a fuel rated rtv. I have never looked to see if it rated for diesel though. I have used it on gasoline in several situations with good results.
James
Rdnck84_03
Kansas
Brass
I may have misunderstood but I believe it is a crack in the return side of the sending unit on top of the tank where the lines connect.
James
  • Like
Reactions: Clb
IDIrty
Canada
Here’s a picture of where it’s leaking on top of shower head. There are small pin holes at bottom and top of indentation. picture is a little blurry, apologies.
Clb
Another old truck
nannyfornia
Ok sending unit, shower head is inside, sorry still brass or fuel rated epoxy...
Clb
Another old truck
nannyfornia
Ps
They like to disintegrate in the tank
Research it and decide what to do. .
Bart F-350
FRANCE
Seen your image It will be a hell of a job to clean that correctly before applying some reparation, be it to braze it with brass (preferred) or otherwise with chemicals.
I have a hard time believing that that piece of pipe is still sound.
I think that when you start to clean it, it will fall apart.
Therefore I suggest you replace.
Vincent
