1993 F250 Diesel 7.3 IDI with 228k miles for sale in Knoxville, TN
Status
Not open for further replies.
Rich Lee
knoxville tn
Hey gang. I was on a lot a few years ago (circa 2015-2017) but I can't find my login info and the 'forgot password' utility here on the site won't seem to send me an email (have tried several times over 2018-2019) so i finally caved and set up a new account. (update: it finally worked, so "rl tn" account is back from the dead.)
Just laying that out to avoid the "new account, went right to marketplace" drama...
I joined the forums back then to get some insight into fixing up my 1993 F250 IDI (IH 7.3), and got some great advice. Fast forward a couple years, and i fixed a bunch of stuff, got some other stuff fixed for me, then HAD ANOTHER KID. That and several job changes pretty much stopped me in my tracks as far as the truck goes.
So here's the sale details.. i link out to a Google Doc and a Google Photo album because I'm geeky like that. I'm hoping to get out of it MOST but not all what i put into it.
Asking $4,000 obo.
Rich (Knoxville, TN)
Pictures
https://photos.app.goo.gl/DN3fVSxAx1vjhkFq9
Details, mostly in the doc - LINK
I haven’t started or driven the thing in over a year, but when I last did, it ran well, although a bit rich… It has a lot of torque, and the new AC had blessedly cool air flowing quickly. I can’t get it started right now, but haven’t tested power, fuses, fuel or air.
Things like turn signals, lights etc. work.
No stereo head unit currently, but i did replace the speakers and wiring.
There’s a dent in the rear quarter panel on the passenger side, and one on the extended cab panel on the same side. The hood has a bend and doesn’t shut tightly but is quite stable. the tailgate is finicky, and the 4wd needs the connecting rod between the in-cab shifter and the transmission to be attached, but i can vouch for the 4wd WORKING in all speeds.
Work done since purchase
  • Treated all exposed rust areas with Rust Converter
    Pulled off old tires and lug nuts
  • New glow plugs (set of 8 Motorcraft ZD9)
  • New glow plug controller (Delphi HDC906)
  • New glow plug relay (Original Engine Management DR1098)
  • New 4WD Shift Linkage (Dorman 600-602)
  • New Ignition (Motorcraft SW2398 Ignition Switch and Lock Cylinder)
  • New Air conditioning system (purchased and installed by Shazzon Bradley of UT Football and prize fighting fame)
  • New solenoid (passenger side wheel-well mounted, from Napa)
  • New Heavy gauge battery cable kit (Ford Battery Cable Kit -- 3/0 Cold weather / hard start option)
  • New windshield wiper motor (purchased and installed by Shazzon Bradley)
    New windshield wipers
    Repaired wiper fluid reservoir
  • New wiper fluid
  • Repaired antifreeze reservoir
  • New antifreeze
  • Replaced front and rear speakers with used units
  • Removed faulty stereo head unit and amplifier (shorting out and overheating)
  • New Fuel Filter (Wix 33217)
  • New Mechanical Lift Pump
  • New Fuel Pump Strainer (1 per tank - Ford E5TZ-9J306-BA)
  • New Front Fuel Tank installed by Shazzon Bradley
  • New Rear Fuel Tank installed by Shazzon Bradley
  • New Fuel Tank Vent Valve (EMSV-2)
  • Dropped and cleaned both front and rear tanks. Replaced one tank as old tank had a sizable leak and wasn’t worth repairing.
New Tires & Lug Kit (details)
4 LT265 /75 R16 123R E1 RWL
BFG BFGOODRICH ALL TERRAIN TA KO2
Center Bore: F:125.00 R:125.00 Lug Torque: 140 LBS
SCH TR13SC 500 VALVES STEEL CHROME
MBM RAZOR 125.00
GOR 9/16 SD HDWARE LUG LUG KIT
Status
RangerDanger
