offroad-anarchy
My ZF5 with 4x4 transfer case is needing some love in a big way. Just trying to sort out what the issue is and if you guys think I might be able to get it back from Montana 450 miles without it blowing up?
This grinding issue has been getting significantly worse in the last 100 miles or so of driving it.
- When I let off the throttle it 'seems like' it's popping out of gear and gives a very loud high rpm grinding sound, where the sound the grinding accelerates the longer I am let off the throttle even though the rpm of the engine and speed of the truck are slowing. The only way to stop it is to push in the clutch and it instantly stops grinding.
- It never does it at all when accelerating from a stop all the way up through 5th to 70mph. Now I can't downshift or fully let off the throttle at all without it grinding big time.
- Last weekend I noticed that if I give it throttle again without pushing in the clutch, the driveline clunks a bit and the grinding instantly goes away and it pulls perfectly again.
- This means it's not popping out of any gear at all, just like two gears grinding against each other when there's no load on the drive shaft. Almost like one gear is spinning the opposite direction to one it's grinding against.
Any idea what it might be and any chance you think I can get it 450 miles to my shop where I can pull it and rebuild ???
Cheers, Pete
Cheers, Pete
