ZF5 Owners I need your help
mexicanjoe
texas
IF you are running a ZF5 transmission with a 4.10 final diff ratio, I need your help. On the ID plate of the ZF5 there is a speedometer code of some sort. If anyone can provide me with the code on your transmission I would sincerely appreciate it. Ford dealer is not helpful here.
I have a zf with 4.10, I can check it this evening when I get home from work unless someone beats me to it.
ROCK HARVEY
Dayton OH
I checked but mine was blank, and I realized you need someone with a 2wd zf-5 since the 4wd ones have the Speedo gear in the transfer case.
Do you happen to know the color of your old Speedo gear? They’re color coded I believe.
Ahhh yeah mine is 4x4, sorry mate
FrozenMerc
SW Missouri
I just did a ZF 5 spd swap into my '85 earlier this summer. 3.73 rear gears, and I think I used a 19 tooth speed-o gear. I keep a little drawer full of Ford speedometer gears just for this very reason. Try one, figure out the percentage that the speed-o is off and adjust the gear the same amount. In other words, if you have a 20 tooth gear and your speed-o is off 10%, go to either a 18 or 22 tooth, depending on which direction it needs to be corrected.
ROCK HARVEY
Dayton OH
I also just realized that from 1992 and up the Speedo reads off the rear axle, so you need someone with an 87-91 2wd ZF5 to check their tag.
mexicanjoe
texas
Alright crew, heres the story: I know Ive got a pink speedo gear with 19 teeth. AT 2100 rpm I show 66 mph but GPS says 59, therefore I think I need a 18 or 17 teeth gear ....
Am I correct in my assumptions? Most days I place the Iphone on the dash and read off of it the speed it shows. NOt great but better nothing.
About 5~ mph off at that speed sound's accurate for factory calibration.
XOLATEM
Virginia... in the brambles
I don't trust the GPS and you prodded me to check my tire height and make a chart of RPM=MPH for my truck.
I have a 29 inch tire and 4.10 gear. The tire height was figured from measuring the loaded radius (center of axle to pavement) and doubled.
Center of axle to pavement =14.5 inches X 2 = 29 inches of tire height.
Once you have that, then you crank in the formula...
I don't have overdrive...yet...so the RPM's will be 24% higher than someone with the same tire and rear gear as me...but how it shakes out is this...
40 MPH = 1900 RPM
45MPH = 2150 RPM
50 MPH = 2350 RPM
55 MPH =2600 RPM
60 MPH = 2850 RPM
65 MPH = 3100 RPM
70 MPH = 3300 RPM
75 MPH = 3550 RPM
80 MPH = drastically shortened engine life...
If you have the same size tire and the ZF and you are figuring your RPM in overdrive (5th) then reduce these numbers by 24% (5th gear ratio.76-to-1)
Then...
70 MPH = 2508 RPM
60 MPH = 2166 RPM
50 MPH = 1786 RPM
40 MPH = 1444 RPM
I think that I am going to start looking for a ZF....
On the speedo gear...the last time I made a recommendation...I was wrong...but...I will try it again...
On the driven gear...
To speed up the speedo in relation to vehicle speed...you...reduce the number of teeth...
To slow down the speedo in relation to vehicle speed...you...increase the number of teeth...
I think that I have that right...we will see if the guys agree or not...
HTH...
Yes you're right.
mexicanjoe
texas
While this may not seem right I have measured the odometer against the mile markers on Interstate 20 I find the odometer to register 10% more than the distance traveled. Ive 2 different speedo gears coming soon : 17 and a 16 tooth driven gear ..... Ill find out which is closer to the right one! Ill keep you posted.
XOLATEM
You'll want to go with a bigger one (with more teeth) to slow the speedometer down.
