WMO= more power? Whats going on here?
MARQ2277
caldwell, idaho
Wow, good call. I had a feeling that it was an air issue. I know with mine, when I am low on that tank, and going up hill, it will suck air for a second some times, and surge; and at other times it will stumble. It has only done the surge thing a few timesk, but when it did, wow.
marq
________________________________________________
1990 Ford F-250 4X4:
7.3 IDI with 120K on the clock:
ATS Turbo with waste gate:
Stage One Injectors (Oregon Injector Service):
Complete Return Fuel Kit (Oregon Injector Service):
DB2 Pump, cranked up with Cold Advance wired permanently on:
4” down pipe, 4” straight through exhaust stopping between cab and bed (no fuff on my stuff):
Torque Converter Lock Up Switch (On/Off/Lock-Up):
E4OD Line Pressure Controller (adjusted to fast/firm shifts):
4” lift w/Rancho shocks:
Big Fat Tires on custom rims:
Tows 1985 fully loaded heavy 28 foot RV (my house) everywhere:
sassyrel
iowa
and if that dont do it---be careful if you have a turbo--esp with miles on it--because if the bushing in the turbo suddenly starts leaking a lot of oil--it feeds direct into the engine--and you could get a runaway--it partially happened to me--luckily--the injection pump shaft sheared---faster than i shut the key off--and killed the engine--if enough oil would have come from the turbo--she'd a blowed---
MARQ2277
caldwell, idaho
You know, . . . I wonder if that caused my sudden surge?? I had thought it was because I was almost out of gas, and sucked air. But it may have built up oil inside the turbo and than sucked it at once, and pow. I do have oil in the inside of the turbo, but it is not much, and I read that there will be some oil always. I only have 120K on the clock, and I have no idea how long the turbo has been on the truck. I do know when I bought it, and after a week I went to change out the filter to a K&N, and when I looked into the compressor wheel, all the blades were broken off, as though some had dropped a bolt down it. At any rate, I had to replace the compressor wheel about six (6) month ago. The compressor wheel was already balanced, and I check the clearance, and oil lines, and drain; It all looked fine. With the K&N filter, and no **** on my stuff, it sounds so cool. You can really hear the turbo sing. It sounds like a jet turbine taking off, . . . it is bad ass.
But, I check on everything once a week, and the next thing I have to do on payday is but chemicals in my radiator to get the mix right.
Marq
Pipeliner_86
IDI up high
Longview, Texas
Those surges of power are pockets of air in the fuel system. I cant personally explaine why it would be a boost of power, but I do know that is what happens when the IP runs out of fuel. Like you guys said, it's as if someone had run into the back of your truck while driving.
MARQ2277
caldwell, idaho
Yah that's what I believe. For a minute, I thought that maybe I could be getting oil from my turbo (oil build up, from a possible leak), but when I checked it out, there was just a slight film of oil, and that is supposed to be on the normal side 9according to my research). It has to do with some kind of lean condition, under a certain rear condition (like you said, I am not quite sure how yet, but I need to research it, 'cause now it will drive me crazy not knowing!!).
Marq
___________________________________________________
4” down pipe, 4” straight through exhaust stopping between cab and bed (no **** on my stuff):
69dieselfreak
well that nice
rimrock arizona
u know maybe the FASS fuel system will help out with our problem
cause dont they say that the system takes air out of the fuel or what ever
MARQ2277
caldwell, idaho
Correct. The way it is set up, it seperates water from fuel, and it has a internal return system which removes the air before the fuel gets to the engine.
Marq
MARQ2277
caldwell, idaho
I don't think so. The way it is set up, it has a return fuel system, like in our IDI, where the fuel is returned from the injectors, and goes back through the filter, and back to the tank. Like our system, when it is working correctly is designed to remove air and to recycle the fuel both to the fuel filter and through the fuel tank.
Marq
69dieselfreak
well that nice
rimrock arizona
well that sounds good enough but the damn things are pretty expensive id like to know of a way to build some thing like that for cheap
pwillis
