Hi All!
The old mule's heater core if leaking. I bypassed it to be certain. Rock Auto offers four choices, with the Motorcraft the $$$, being 3x the price of the other most expensive option. Which is the "best" choice? Also, is it worth it to look into getting the OEM repaired? I didn't do a search, but is it a time consuming job?
RockAuto choices:
https://www.rockauto.com/en/catalog...4378,heat+&+air+conditioning,heater+core,6864
Many thanks...
I did research this quite extensively and very recently (my old heater core is out right now and bypassed. Not always as easy as everyone says IF you want to do it exactly right. (like I do) with the foam seal in the correct location, blend door or outside air door operating properly and not getting obstructed, etc. (I have a problem with one of those).
I honestly spent 2-3 days LOTS of hours each day searching for a brass/copper heater core, researching the different manufactures and as some already mentioned, they are ALL aluminum, even those that show an image that appears to be brass/copper <--- those are aluminum -the images are misleading.
I chose the
APDI/PRO 9010205 because that company provided the most (amount) of technical information on their manufacturing details.
They have a special coating that prevents electrolytic corrosion. I think that most, if not all of the aluminum cores have such a coating but some sellers don't even mention it (probably don't know about it)
THAT (corrosion)
WILL be a problem if you have a Brass/copper radiator and any stray current to ground in the truck, (which I think that most of these old trucks will have), will cause a small current to flow from aluminum heater core to the brass radiator and carry some aluminum ions with it until the heater core develops pinhole leaks or worse. It is this galvanic corrosion though electrolysis which causes these aluminum heater cores to fail prematurely.
NOW, if I have the direction of current flow correct,
it might be interesting to note that a NEW Aluminum Radiator could be subject to the same electrolysis issue and corrosion IF you have an original brass/copper heater core. Metal ions would be removed from the Aluminum and carried toward the brass heater core.
All manufacturers certainly must be aware of this by now and coat their aluminum heat exchange components (radiators and heater cores) HOWEVER:
IS THE COATING USED TO PROTECT THESE ALUMINUM COMPONENTS ADEQUATE TO PROTECT THEM?
MAYBE but I personally am NOT going to trust the coating. The amount of stray current in the truck could be a factor that determines how long the parts will resist corrosion.
EDIT: The primary solution or preventive measure is to check the ground connections in the vehicle to make sure they are all good grounds with no loose connections or corrosion, no broken ground wires. The factory manuals describe the location of every ground in the vehicle. I would start with Negative battery cables and engine ground straps in the vehicle. Ground wires from the factory are always BLACK and connect to the metal frame or body.
Someone posted about
GROUNDING THE HEATER CORE to remedy this potential problem. I have read about that before, it makes sense....
EDIT: DO NOT GROUND THE HEATER CORE. This Warning was issued by Ford in a second Technical Service Bulletin related to the Heater Core Corrosion Issues. See post #35 in this topic thread.
