Okay all,
Some of you have seen my post in the "What you did today" thread.
My wheel seal on the passenger side is leaking, I'm sure the drivers side isn't far behind...
What socket do I need for the hub lock nut? I'll likely be getting it at Advance Auto locally but I could order it on amazon or the like if I need to. I saw someone said Autocraft AC649 is the right one but other people said it's too small.
Is there anything else special I'll need for this job? Truck is a DRW 91 F350 with a Sterling 10.25
Can the shoes be changed without a special spring tool? I saw @towcat posted one a while ago in a seperate thread. I have the "right" tools for average drum brakes. The screwdriver with a socket looking thing for the spring retainers and the tools that slide over the pins to install and remove springs.
I will probably just bite the bullet and order 2 of the 34384 SKF Scotseals and new shoes. The hardware looks fine, and I really can't afford to replace what's broke now lol.
