whats a good oil filter wrench?
chris142
SoCal
My oil filters seem to get stuck on the engine. I lube the gasket and don't crank em on very tight. But I have a terrible time getting them off. The ones I'm using dont have a flat gasket. Its beveled and I wonder if that's making them hard to get off. I broke 2 of napas strap wrenches tonight. Pulled the spot welds right apart.
Ruger_556
Ferndale
Buy a better strap wrench and follow the directions printed on the filter... I believe it's 3/4 turn past but I could be wrong. You're not using a wrench to put them on are you?
chris142
SoCal
I am using a wrench to put them on. But to the recomended 2/3-3/4 turn. I cant get it tight enough by hand and they leak if I dont put a wrench on it. I'm not cranking it on till the cows come home though.
Nrliftedranger
North Royalton Ohio
Hope Your not using farm filters they tend to do that easily for some reason I put mine off and on by hand no need for a wrench unless there on there to long. Try
Using assembly lube on the o-ring maybe..
chris142
SoCal
Just say no to frams! The one I took off today was a purolater that's identicle to the fl1995. I put a baldwin on it this time. I have fought all of them regardless of brand. I broke 2 strap wrenches today. One from azone and another from napa. Both imported junk. I have one I got from the snapon guy.its like a belt and has a socket on it. It just slipped
Poway, CA
I like the belt style, the one where you throw the handle onto a 1/2" drive wrench and go to town. Usually end up denting the filter to get it to bite, but who cares? It's coming off anyway.
Mike
Ruger_556
Ferndale
I tend to like oem parts so... Mine always had either a Ford or Fleetguard filter on it
fordf350man
Rockwood MI
i dont like the strap wrenches, i use the cup with the socket wrench, much easier, but i do only tighten them by hand, and i use the powerstoke motorcraft filter on my truck and it comes off easy, always lube the seal with the oil first
Ruger_556
Ferndale
I put them on and take them off by hand :dunno Maybe I'm superman? I only break out the strap wrench on heavy trucks...
junk
Paullina, IA
I use a strap "wrench" It has a chunk of seat belt material in a 3/4" hollow square bar. You put a 1/2" ratchet in the end of the bar to wrap the strap up around the filter.
I never use a wrench to tighten any other filter, but my diesels. The diesels I've had seem to leak slightly if I don't put them tight with the strap wrench.
bleachasaurus
