what thread
flatlander
plays dirty when losing
ft. wayne IN
I need to clean up a rear end and I'd like to plug the breather hole on the left axle shaft so no water gets in. It's bigger than 3/8-16 and smaller than 7/16-14. Maybe a 7/16 fine thread?
Devilish
Nv
I don't know what size it is without looking at it myself but a cork from the hardware store would do the job too. Look in the nuts n bolts area.
geonc
SPIDER BAIT
NECKVILLE North Carolina
It's 1/8 NPT {pipe thread}
IMVHO ---do not plug it!
Just run a longer hose. All you will need is a barb fitting and some carb/vacum vent hose from either the big box stores or local parts house.
The hose can be 6 foot long if you are that worried about water getting in!
But if you are running that deep, you will also need to snorkle the t/case and tranny vents, and front diff as well!
Plugging off will only trap the heat and eventually lead to seal failures!
subway
be nice to the admin :D
York PA
dont plug it permanantly or the seals will go from the expansion with the heating and cooling.
if you are just covering it to clean it get a 1/8 pipe plug
Dsl_Dog_Treat
Decatur,MI
Hey Barn, this is the one that gets cleaned up and painted hot pink for Mel?LOL
Big Bear
