No telling really. With either one.
My 87 will turn 00000 this week. Don't know if it's 100k or 200k or 300k etcMy 93 has 40k on the clock' stock lift pump.
So 40k+
After reading many of the thoughts on the subject, at some point I'll be going with an electric pump. The main reason why, is I've already just replaced my mechanical pump, that was leaking. However, when I did it, I was also replacing the thermostat; so access was 'eased' by having topside access. It would seriously suck to have to do this from below just from the diesel alone.
The idea of having a topside electric pump, mounted on the fender behind the battery would make future work, way easier.
Just an fyi, I ran stock pump for a year on WMO and switched to electric because of prime issues (Mr Gasket green) that only lasted a couple of months and went back to stock. Oil if not diluted is ******* pumps, but the stockers do pretty good. I still like the electric better but need an oil friendly one. Until then the factory pump is a tried an true answer.
