What is better to run,. WMO or ***?
Darrin Tosh
IDI Hound
Grand Rapids, Michigan
Just wondering what is better to run Waste Motor Oil or Wast Trans Fluid? i have a 55 gallon barrel of *** that I can start filtering, but I also have plenty of WMO.
What would you rather,...?
gearhead
Lewiston/ID/USA
both?
run a bit of oil then run trans fluid to clean everything out,then run the oil,then the trans fluid.Or just burn everything.
the *** would be a little thinner maybe so easier to run?
just filter and clean both of them well.
tknomaj
Anaheim Ca.
I would guess in Your line of Work You are scratching Your head and saying *** all the time . But to be saying it so often that now You have a 55 gallon Drum full of it is just too Much:rotflmao
Darrin Tosh
IDI Hound
Fill your vehicle up with ***..., LOL.
Oh Hell,...I didn't even realize that until I read your post,..Pretty funny LOL
Ok Lets make it WATF,... I guess.
You have no idea,...LOL
rjjp
Needs to go test
Clare, Mi
Like stated above, mix it... You don't want red fuel, the LEOs will love you if you do. BTW I lucked out on this before, they didn't check the back tank.
subway
be nice to the admin :D
York PA
*** seems to run better for me, it flows better and needs less heat to thin it nicely.
itsacrazyasian
residentcrazyasian
boca raton, fl
i run watf and a little wmo mixed in. Usually like 15 gal of atf and 5 gal of wmo. i notice my truck is easier to start with a little bit of wmo or diesel in it but it runs great otherwise.
