What does this do ?
Jason1377
Arkansas
In the picture below it's on my idi just like all idi's before the transmission right next to the oil filter was looking at my starter the other day a seeing if I had any rust from crappy road salt n noticed it has me curious, also any one have a good free place to look up all the parts to 93 non turbo idi.
Example wire specs n so on. Seen a idi in scrapyard all but the transmission is there an was going to use it for parts or rebuilt it's a 93 7.3 motor is half there but parts I got off it is the reason I ask
That engine has a horrible main seal leak and the owner installed a drain tube.. Not what should have been done. Fix the leak was the better idea.
Jason1377
Arkansas
It's a og 93 idi and I'm the 3rd owner n have all the matience records original motor as well and it was a seal leak can I just replace all of it. Also @79jasper will that drain tube effect anything since ive owned the truck never had an issue with shifting gears though it's a e40d, other the a vss needed a cleaning a basic maintenance
nostrokes
Colorado
That drain tube has nothing to do with how the truck will perform.
genscripter
Inglewood, CA
Looks like just a drain tube on the flexplate/flywheel cover.
On all my later year IDI's, they had that drain tube on the flywheel cover. But my early year ones didn't. I just assumed it was something stock with the 90's years models.
The early year flywheel covers (in my experience) had a small weep hole at the lowest point. I don't think it was the purposeful intention of the PO to install this drain bib to cover up a rear main seal issue. But who knows.
Jason1377
Arkansas
Ok cool I've seen it on one other truck in scrapyard close to me that I've got parts for my truck from have just been curious as to what ur was. Thanks guys for answering.
I periodically run thru a full truck wash station that does top an under truck washing n seen it figured i ask since still learning more bout idi's
Thewespaul
Bulverde, Texas
The flywheel covers (zf5/t19) do not have the tube but gills. The flex plate covers on all E40ds have this tube. C6 flex plate cover has a small vent
nostrokes
Colorado
My cover doesn't have that tube... But then again nothing on my e4 has been standard it seems..
My 89 rig with the original E4OD did not have this not again..who really knows.BTW I have never seen this drain tube in any wrecking yard trucks.
Thewespaul
Bulverde, Texas
Hmm all our e40ds have it... maybe that’s the secret to why our Texas trucks stay rust free? Not that it has anything to do with salt
rwk
S.W. mich
Ours also, they fell off by the time they got to Cal., made just down the road from me! lol
Jason1377
Arkansas
My title says 1993 my sticker on driver's door says Nov 1992 so just has me rubbing head as to what yr it is n the VIN says 1993 as well so I know most time a rig is made then sold a few months later
Thewespaul
Bulverde, Texas
Did you know you can buy a 2019 Kia already?
Ramtough01
