Weird starting issue
S-west
Ct
So my truck starts fine every morning even whèn in the single digits it starts with one cycle of the plugs and a few seconds of cranking. And when my truck is hot it will start right up without problems. But when my truck is still warm enough so that the glow plugs don't cycle, but been sitting for a while so it's not real hot (like 30 minutes), the truck will crank and no fire. But if I let off the key and crank it over again it starts right up like its hot (i usually crank it for about two seconds the first time, but once i let it crank for about 10 seconds on the first crank and it didnt start). My first thought was air intrusion but if I wait even longer to start it and the glow plugs cycle again, it starts right up. And the truck shows no signs of air while running. My truck has an electronic lift pump by the way.
Hyde
N GO SEEK
Idaho
Mine has a similar issue, will start fine overnight or long periods of sitting, or less than an hour or so. But if it sits for 1-2 hours it will start and immediately die, then start after a 10-15 second crank and run fine. I was thinking air intrusion as well, except it wont do it overnight. Electric lift pump here too.
S-west
Ct
Now that I think about it. Could this be like the start of heat soak? Similar to the way coolant gets hotter when you shut the truck off before it gets cool? Maybe the pump gets hotter and it's just enough to mess with it? I hope it isn't because I don't have the money for a moose pump yet.
S-west
Ct
My truck did the same thing that your did when I had the mechanical pump. But I just put the electronic one and now instead of starting and dieing it just cranks longer.
S-west
Ct
That's what I was afraid of. The pump on it has unknown miles because the original one went and I had this one sitting around. Now I need to find a way to come up with some cash for a moose pump
Houndsman
Turlock, California
Ya, I'm ordering a moose pump as well befor I start to have that problem I have 500 right now working on the rest, lol I'm also sending my ats turbo off to Russ to get upgrade, along with new bb injectors, have you messed with the wires on the pump at all? Clean them make sure there tight and clean the battery connections?
S-west
Ct
I'm from connecticut. I haven't messed with anything on the pump but its been fine for about 6 months and the problem has started over the last month or so.
pwillis
