Weekend Project
Discussion in 'Lounge' started by Thewespaul, Nov 11, 2017.
  1. Thewespaul
    Thewespaul Supporting Member Supporting Member
    1,704
    473
    Jul 27, 2015
    bulverde texas
    Recently picked up two trucks here for my dad’s tree service, a 97 f350 cclb 2wd with psd and e40d. Only 90k miles and paid 4K.
    Pics coming
    Needs some work, air box is not sealing so I did a 6637 mod from parts I had laying around in the shop. Front seat was trashed so I pulled a front bench from my 82 and bolted it right in. Rear bumper was a pretzel so I pulled the bumper of our 6.0 that burned down. Did some fixing with fire and it bolted in too.
    Next truck is a 2000 international 4500 with dt466e. Has 52k miles on it and came with a tranny named Alison. Paid a painful 11k but it will be worth it for the company. Can’t find a driver worth a hoot anymore so I’m replacing clutches and rebuilding Eaton 6 speeds every other month, hopefully the auto solves that problem.
    This truck is what the main project is this weekend, going to cut the frame down move the axles and set the bed and bumper on it from a retired chip truck of ours. Here’s what I have done from yesterday.
  2. Thewespaul
    1,704
    473
    Jul 27, 2015
    bulverde texas
    Have her a wash a fixed the front bumper with skid steer 3E7BD6FB-F53F-4B8C-B9AC-44324DB17AC5.jpeg
    New bench seat 1F43E81C-6D2C-4D01-96B2-33B26F40CA25.jpeg Installed (blue seat in a grey interior I know) FD044939-4A81-4AC5-B80F-DF83F072E97F.jpeg New bumper bolted and welded in E4ACB19B-92EE-49FB-9DBE-55575E33F7F5.jpeg
    Intake is in
    Gonna be a great truck for the crew
  3. Thewespaul
    1,704
    473
    Jul 27, 2015
    bulverde texas
    Torched all the u bolts and the rear end off C1257820-A79D-41DF-91B6-9819D7AD1EEC.jpeg 01DA9D08-513F-4A67-905C-37E3D263F0F2.jpeg Pulled the bed off and pressure washed the whole frame before bringing it into the shop, went to fire up the old jd450 and blew a hydraulic fitting, only had one plug so made it work with this 30E0EF58-E67D-40CC-A310-AE1A8FB23200.jpeg Brought the truck into the shop and got started by wire wheeling the frame
  4. Thewespaul
    1,704
    473
    Jul 27, 2015
    bulverde texas
    Unbolted crossmembers and took the front driveshaft out, going to move the whole assembly up and just remove one carrier bearing. Drilled front carrier bearing bracket holes and bolted it up, used a come along to bring the rear end up after disconnecting harnesses and brake lines. Bolted the driveshaft up and punched the holes for the leaf spring mounts
    92391EB1-6087-428C-9B52-0FD6689B9F8E.jpeg CD77E88A-6963-4E92-A0BE-F4DD645641B3.jpeg
    chillman88 and FORDF250HDXLT like this.
  5. Thewespaul
    1,704
    473
    Jul 27, 2015
    bulverde texas
    Made a lot of progress yesterday, doesn’t look like much but did a lot of measuring and drilled all 42 holes through an inch of frame. Everything is bolted up and lined up really nicely. 4F94ED25-C584-42A4-9EDE-95FB976FB73B.jpeg 91CDE078-6528-4AE1-A044-4153292B1DEA.jpeg C6DEA38F-30B7-414E-A6AE-EA3D3936C2A2.jpeg F6228506-FEE4-4682-8A23-AFD898712213.jpeg
    bbjordan likes this.
  6. Thewespaul
    1,704
    473
    Jul 27, 2015
    bulverde texas
    Ran out of steam Sunday, friends showed up and we went hunting and didn’t do a whole lot. I bled the brakes and took the truck for a drive. No vibrations and the frame is still super solid going over uneven ground. Man this thing’s turning radius is insane, it will turn around in a tighter area than my 2wd obs. Gonna work great for the tree service!
    If anyone on here is going to do something similar I highly reccommend this toy, think of it as a magnetic drill press but it’s much more than that, the bit it uses really is the key. It works like a hole saw a cuts out the outside diameter of the hole and pops out the inside piece with a pin and spring once it drills through. EFA41AB4-1FC9-40DA-955C-CA8E5702AD5E.jpeg 0FAFCA70-86E1-40B0-92E9-4896AF70D34F.jpeg 05C068C9-18EC-45BD-979A-D8994897C43C.jpeg
    If you tried to do this job with a regular drill you would hate everything :joker:
    jrad235 likes this.
  7. sjwelds
    sjwelds Full Access Member
    1,101
    76
    Dec 30, 2013
    Central KS
    Been there, done that many times. The mag drill and annular cutter is the answer.
    Thewespaul likes this.
  8. chillman88
    chillman88 Supporting Member Supporting Member
    553
    172
    Feb 22, 2017
    Central NY
    We have those at work. Best part is the electromagnet! I'd hate trying to hold that thing to drill lol
  9. Thewespaul
    1,704
    473
    Jul 27, 2015
    bulverde texas
    Yeah they are super slick. Mine came with a coolant bottle to fill with cutting oil, do y’all use it? It really didn’t seem to be working so I just used some pb, only killed one bit
  10. sjwelds
    1,101
    76
    Dec 30, 2013
    Central KS
    We use a water based cutting fluid, I believe it's called "Kool Mist".
  11. Thewespaul
    1,704
    473
    Jul 27, 2015
    bulverde texas
    Right, but did you notice the level in the bottle change at all? It didn’t seem to drain on ours at all
  12. sjwelds
    1,101
    76
    Dec 30, 2013
    Central KS
    Ain't got the fancy bottle nonsense, we just mix it in a el cheapo spray bottle and spray it on the bit roughly every 1/4" of travel, depending. If we're going deep we pull out and lube (just leave it alone, alright?) and then go again.
    Hate to see you eating bits needlessly. Them things ain't cheap. Truck frame is harder than mild steel tho....
  13. Thewespaul
    1,704
    473
    Jul 27, 2015
    bulverde texas
    Yeah for how much drilling had to be done I wasn’t too upset with one bit getting eaten. That frame is hard stuff and this frame was sleeved to lengthen it too so essentially drilling through two frames. I’ll use cutting oil in a spray bottle from now on then!
  14. Nick382
    Nick382 Full Access Member
    111
    11
    Jul 26, 2017
    Ohio
    You sure get a lot done in a weekend. I feel a little lame now !
  15. Thewespaul
    1,704
    473
    Jul 27, 2015
    bulverde texas
    Haha well thanks, having the right tools and some experience doing this kinda work makes it a lot easier;Sweet
Share This Page
