N.E fjord-by-fjord 2fiddy
My last (and first) post yielded immediate answers to an apparently common question... The 1/4 tank showerhead issue. Someone suggested I search for other threads about it. This time I took that advice first and did just that... But I couldn't find anything. Maybe I just suck at thinking of search words...
Anyway..
I've noticed that at speeds of about 45-75mph, at around 50-80% throttle, and I'm pretty sure mostly when letting OFF the throttle... I get a sort of vibration coming from my drivetrain. (i think) Also, if I'm on it pretty good while accelerating there is a hesitation to shift up to the next gear preceded by a slight jump in engine rpms, which results in almost a small "gallop" feeling when the next gear does engage...
For all I know it could be separate issues, or related so i figured I'd mention both.
So... With my VERY limited knowledge, I decided to wiggle some stuff around before I posted to try and bring more details with me:
I hadn't checked the front (manual) hubs since I got her. As I assumed, they were unlocked. So I spun the two front axles, and all that's good and smooth... So it's not front.
Then I grabbed the rear drivshaft while I was parked outside the bottle return. The u joints all look and feel solid, but I was able to freely rotate the shaft about a 1/4 turn... I thought this seemed rather suspect, so I thought of mentioning it. Seems to me like that might mean some parts in my diff/transfer case may need some attention...
That's about all I know so far. Any ideas on what it might be, what it definitely isn't, or what to check next would be much appreciated. Thanks!
Anyway..
