Well today I'm supposed to be cleaning up my garage. So I did what any sensible male in their 30s does and didn't do that.
Instead I tore apart a known bad vacuum pump to see how they worked and wanted to share. Surprisingly they are very simple, and may explain why some of the no named ones go bad so quickly.
First I took off the pulley adapter housing. Turns out its full of lube of some sort. Maybe 'new ones' dont have lube in them and the cam lobe is failing? Food for thought.
Then I used a dremel to cut off yhr rolled crimp lip and separated the two halves. This one failed cause it was full of water and corroded. But oddly thr diaphragm was still in good shape.
Anyways. Back to cleaning I suppose.
