gabbyr100rs
Gents,
I managed to get the old pump out and the new one in.
In the process, I discovered that the two jaw pullers that I have were not up to the job (jaws too thick to get behind the lip on the pulley) of getting the pully off, and since all the parts stores were closed for New Year's Day (you know where this is going, right??) I got out my heat gun, got the pully really hot and drove the old pump shaft out of the pully since I did not need the old pump for a core. Old pump now good for a trot line sinker......
Unfortunately, in getting the pully off, I must not have supported it evenly enough during the removal process, and it now has a definate wobble during operation when mounted on the new pump. Putting the pulley back on just took the right size and length bolt and a fender washer to pull the pully back onto the pump shaft--no "love taps" with the BFH. My '91, as you prolly know, does not have the serpentine belt, and the vac pump belt runs off the alternator pulley.
I am afraid that unwanted vibration caused by the out-of-true pully will bring my new vacuum pump and drive belt to early graves . It isn't making any racket, the pulley is just out of true and therefore wobbles. That said, my question is what kind of puller or tool is required to get the pulley off without destroying the pump, and where is a good place to access same?? I expect to have to order a new "non-wobbler" pully from the Ferd store.
After all this to cure an intermittant brake warning light, the brake warning light may have been caused by the silly switch that is mounted on my parking brake assembly rather than a dying vac pump. The light came on after the pump change, and I started messing with the switch,cycling it up and down by hand, and it went out and stayed out. After 150K, the old pump was due for a swap anyway--taking that position makes me feel better about the money and effort anyway. I think my brakes are a bit more responsive--I recon I'm getting more vacuum out of the new pump. I suppose one of our members reading this is going to point to his '86 model with 487,000 miles still running happily on the original vac pump, though......
Thanks again to the collective font of all IDI knowledge. Good to be an OB member.
