Vacuum Pump Oil?
jrollf
Houston, TX
I just bought a new Delphi vacuum pump for my 7.3 IDIT. With it came a note stating 'Belt driven vacuum pumps require 10cc of 90wt hypoid gear lube. Top up as required. I've never heard of adding oil to the vacuum pump... did i miss something, should the pump be checked and topped off every oil change?
I assume I have to take the bolt off the back cover to fill it? (No instructions were no provided)
Thanks!
1993 F350 Crew Cab Dually
XLT
7.3 Factory IDIT w/Banks Sidewinder
5spd Manual
dgr
sac town
Tagging along. I'm curious what the level is so we can top it off to the correct amount
riphip
Memphis, TN.
My Motorcraft VP didn't come with such disclaimer. Guess they got it right the first time.
jrollf
Houston, TX
I removed the bolt on the back and it was filled with oil to the bolt hole, kind of like how full you would fill a differential (to the fill bolt)... Not sure if that is right or not.
  • Like
Reactions: dgr
DaytonaBill
USA
I know somebody who uses STP for the vac pump...
In the ten years I've had my F350 CCLB, I've grenaded three of them so far...
SLC97SR5
UT
I changed my vac pump oil 8 years ago with some 80-90w synthetic gear oil. I filled it to the fill hole. No issues before or after.
riphip
Memphis, TN.
That's funny. Why did you need to buy a motocraft vacuum pump?
Didn't need to, chose to buy Motorcraft.
I have been thru the remans, off brands, etc. Motorcraft always lasted longer than the others since 1992 on my trucks for me.
dgr
sac town
What was the failure mode on all your vacuum pumps? Mine, it quit providing adequate vacuum. That's about the only failure I read about on these here.
jrollf
Houston, TX
Actually... none [emoji15].. had a high pitch squeal coming from that area (combined with my bad hearing), convinced myself it was the bearing on the vacuum pump, 'cause it couldn't be the belt tensioner as I just replaced it a year ago. Well.... it was the damn tensioner, my factory original vac pump is just fine. Now I have a spare vacuum pump. [emoji16]
XLT
5spd Manual
  • Like
Reactions: dgr
DaytonaBill
USA
All three of mine came apart internally and the back cover came off one but still pumped vacuum... cookoo
Cubey
Van dweller
USA
The two I've replaced (1 each on truck and RV) just quitting creating vac. The truck's got weak but was still very usable for braking, then one day put out almost nothing. RV's was weak so I replaced it before it totally died. Ended up swapping the truck's new one from mid 2017 over to the RV because it's a lifetime warranty one from Oreilly. I can walk into any and get another if it dies.
Bsthomas21
