farmboy9090
Was wondering what is the easiest way to remove the pulley off my old pump to put back on the new one. Want to do it the correct way to prevent damage to pulley or the new pump. Thanks.
Tyne power steering pulley pullers won't work for the vacuum pump pulleys.
false
Thanks for the replies, will have to check to see if the old pulley has a lip on it so the tool can catch it and pull it off. Napa had one that I found on their website.http://www.napaprolink.com/detail.aspx?R=BK_7769253_0006392273#. I dont know if Napa lets you rent it like autozone or what.
If you can get my power steering pulley puller to remove the vacuum pimp pulley then it's all yours.
The cams that lock down over the pulley are just large enough in diameter that they interfere with the pulley itself allowing it to not seat properly.
So let me say that not all pullers will work.
