Used ZF-5 speed, Question on checking condition
sjwelds
Central KS
As I understand the lever inside the tcase attached to the pump to keep the pump from rotating just bears against one of the ribs cast into the transfer case. since the pump is "floating" if you will eventually the tab wears through the rib allowing the pump to spin, thus preventing the pump from pumping, thus killing the tcase. The fix is to weld an additional chunk of steel to the pump lever to make a wider footprint of surface area to bear against said rib, thus preventing it from wearing through.
Correct me if I am wrong.
pwillis
