us gear overdrive
whitehorse
Jacksonville Al.
Well... going this evening to get a 86 crewcab with a 7.3 and a 4spd with a us gear overdrive on it. What do i need to check to make sure it works? Seems like i seen a thread on them but not sure....thanks for the info.
Much of what I know about them I have gathered from this forum. Mostly they will not shift if you keep your foot on the throttle. You need to lift off the throttle and they shift. They are noiseier than the Gear Vendors and will run warmer too. They are direct gear drive where the GV is a cone clutch drive powered by hydarulic pressure gained at about 25 mph. The US gear can shift in with no problem from a dead stop too so it splits first gear under of over. Just depends on which unit you have. Easy way to figure out what it is will be to drive it and see if it speeds up the final drive of lowers it. Spped up os overdriving and slowing down is underdriving it. Post back what you find. I don't believe these are supported any longer either. Some have "talked" to US Gear and didn't get any help. They either are just doing this for hp racers or doing nothing at all any more..:dunno
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
DUmb question, but how did you find out that it's a U.S. Gear unit? The ad doesn't say...did the seller tell you?
Granted there's only one cab pic, but I didn't see a shift knob, and I see something on the floor near the gearshift lever that almost looks like a transfer case shift lever (even though this is a two wheel drive)...makes me wonder if that might be the base of a shift lever for a Mitchell or Ranger gearsplitter?
BTW, that's a nice looking truck ;Sweet
Wow.. What a terrible posting on craigs list. I had to read it a few times to understand what tran the seller is talking bout. I have never seen the word "for" to mean its a 4 speed trans. Thats a new one 4 me...:eek::angel::sly
The Warden
MiB Impersonator
Ouch...if you could have talked him down far enough, it might have been worth it, but $2200's way too much. With a bad engine and brakes, MAYBE $1500 if you want a project truck that could turn out nice in the long run...
Thats kind of a sad ending to the truck. Many times the knock is just a bad injecter but without being there to listen I wont say to go back and make an offer. It could very well be a rod or piston or main knock. With bad brakes you have not said whats wrong but a bad clutch turns this bad from the start. Usually these items you see and feel are just the begaining of whats under the pretty stuff. Someone didn't take care of that rig. Sorry it was a bust..
whitehorse
Jacksonville Al.
So tell me guys... the knock was not there at idle but any fuel it would start knocking...worse when the engine was pulling the truck. let off the fuel pedal and would go away. The noise was in the head...at the #1 injector area. Clutch was wore out brakes was bad but had a new vaccum pump and master cylinder. Did I bale too quick? One thing i left out...while driving the glowplug light would come on and go off the whole time i was driving. It would dim the lights and go back off...i heard this might cause the knock...what yall think?
Caterpillar335
