Upgraded belt tensioner pic request
cpdenton
Truck needs paint.
Conway AR
Upgraded belt tensioner install pics(update)
I bought one of those fancy belt tensioners with the shock absorber built in.
Did some searching, but couldn't find a picture of where that bracket for the shock bolts to. Anyone have a picture?
I hope this helps control some of the flop I have in my belt when it's running.
Thanks in advance.
Chris
cpdenton
Truck needs paint.
Conway AR
Here is the new upgraded part.
I think it bolts to this area here between the ac compressor and the vacuum pump.
ironworker40
NYC Ironworker
nj
They came with a whole new bracket for the ps pump/ac/tensioner. Im not sure if you can adapt it to the original bracket. What tensioner do you have now , open spring type?
cpdenton
Truck needs paint.
Conway AR
Ahh. Ok. I'm going to give it a go. I have a closed spring type tensioner. Looks just like the upgraded one, without the shock and tab for mounting it.
cpdenton
Truck needs paint.
Conway AR
I noticed the bracket I have on my parts engine does not have the holes that are in the ac compressor bracket on my truck. Looks like to me I have 2 holes that are right in that picture I postd between the compressor and vac pump that the bracket might line up with....
ironworker40
NYC Ironworker
nj
I found this tsb
'92-'93's had a tensioner with the external spring.The best repair is to find a newer p/s bracket with the internal spring tensioner and install.Also install the shortest belt that will go on.
TSB 95-5-22 ACCESSORY DRIVE BELTS - ALL 7.3L IDI DIESELS - COME OFF ACCESSORY DRIVE PULLEYS- VEHICLES
BUILT AFTER 2/15/92
ENGINE - ALL 7.3L IDI DIESELS - FRONT END ACCESSORY DRIVE MISALIGNMENT - FEAD BELT TRACKING ISSUES - VEHICLES BUILT AFTER 2/15/92
Publication Date: MARCH 13, 1995
LIGHT TRUCK: 1992-1994 ECONOLINE, F-250
, F-350, F-47
This TSB article is being republished in its entirety to include the latest level parts and to update the service
procedure.
ISSUE:
Some diesel-powered vehicles are experiencing drive belt tracking concerns. This is caused by Front End Accessory Drive (FEAD) misalignment, which may result in the belt coming off the accessory drive pulleys. If this occurs, several warning lights will illuminate and the vehicle will lose generator and A/C function and water pumpcirculation. In addition, steering efforts will increase and, after one or a few brake applications
, brake efforts will progressively increase.
ACTION:
Check and align the FEAD. Replace worn pulleys, A/C-P/S-V/P (air conditioner - power steering- vacuum pump) bracket and tensioner and install rubber-backed belts. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
REMOVAL
Disconnect the battery negative leads from all batteries.
NOTE: COMPONENTS INSTALLED BY FINAL STAGE VENDORS ARE NOT INCLUDED. REMOVE THOSE COMPONENTS AS NECESSARY TO CHANGE THE A/C, P/S AND V/P BRACKETS.
Remove the air intake
tube on F-Series. Also, reduce coolant and remove the radiatortop water hose.
Remove the fan, clutch and shroud (LH thread on fan clutch nut). Use Fan Clutch Pulley Holder T83T-6312-A and Fan Clutch NutWrench T83T-6312-B.
Remove the belt from the tensioner and discard.
Remove the vacuum pump and power steering
pulleysusing Steering Pump Pulley Remover T69L-10300-B.
Remove the A/C compressor, vacuum pump and power steeringpump from the bracket.
NOTE: IT SHOULD NOT BE NECESSARY TO BREAK ANY HOSE CONNECTIONS.
Remove the bracket, tensioner and routing idler from the cylinder head.
INSTALLATION
Install the A/C-P/S-V/P bracket (F4TZ-19E708-D) to the cylinder head. Tighten the three (3) fasteners to 47.5 N-m ±7.2 N-m (35 lb-ft ±5 lb-ft). Refer to Figure 1.
Figure 1 - Article 95-5-22
Install the tensioner (F4TZ-6B209-C) using the T50 Torxbit and tighten to 62 N-m ±9.4 N-m (46 lb-ft ±7 lb-ft). The sub-bracket is attached to the flange on the main bracket adjacent to the vacuum pump location. Use two (2) new bolts (N605906-S2) and nuts (YF-1581) and torque to 27 N-m ±4 N-m (20 lb-ft ±3 lb-ft).
NOTE: THE TENSIONER LOCATING PEG MUST BE IN THE BRACKET HOLE BEFORE TIGHTENING THE TORXBOLTS.
Reinstall the vacuum pump. Tighten the three (3) bolts with a 10 mm socket to 27.5 N-m ±4.2 N-m (20 lb-ft ±3 lb-ft).
Reinstall the power steeringpump. Tighten the three (3) bolts with a 17 mm socket to 47.5 N-m ±7.2 N-m (35 lb-ft ±5 lb-ft).
Reinstall the A/C or non-A/Cidler pulley and torque to 27.8 N-m ±4.2 N-m (20 lb-ft ±3 lb-ft).
Reinstall the belt routing idler and torque to 55 N-m ±8.3 N-m (40 lb-ft ±5 lb-ft).
NOTE: VERIFY THAT THE PULLEY IS CROWNED: F4TZ-8678-A.
Reinstall the vacuum pump and power steeringpulleysso that the pulley hub is flush to the end of the shaft 0.00 ±0.10" (0.00 ±0.25 cm). Use Steering Pump Pulley Replacer T65P-3A733-C.
Verify assembly sequence of Navistar shims (E3TZ-6B306-A) 0.090" (2.3mm) at crankshaft-water pump pulleys, refer to Figure 2. The preferred assembly is with a pulley ring (E3TZ-6B306-A) in front and in back of the crank pulley and the spacer plate in front of the water pumppulley, only. Tighten to 32.5 N-m ±3 N-m (24 lb-ft ±2 lb-ft).
Install the new rubber-backed belt (F4TZ-8620-T with 130 AMP generator; F4TZ-8620-L with 165 AMP L/N generator) according to the belt routing decal.
Loosely route the belt over all pulleysexcept the routing idler.Assure that the belt fits correctly in all grooved pulleys.
Swing the tensioner to the installed position and slip the belt over the routing idler.
Reinspect the belt fit on all pulleys.
Reinstall the fan/clutch and shroud using Fan Clutch Pulley Holder T83T-6312-A and Fan Clutch NutWrench T83T-6312-B.
Tighten clutch nutto 133 N-m ±20 N-m (98 lb-ft ±15 lb-ft).
Tighten the four (4) shroud bolts to 6.5 N-m ±1.5 N-m (5 lb-ft ±1 lb-ft).
Resecure the top water hose. Tighten to 3.73 N-m ±.61 N-m (33 lb-in ±5 lb-in).
Reinstall air intake tubes. Tighten to 9.0 N-m ±1.4 N-m (80 lb-in ±12 lb-in).
Service the coolant system.
FEAD ALIGNMENT PROCEDURE
ITEM PROCEDURE
Check water pumppulley diameter and fan clutch. The correct water pumppulley is stamped 1816349C1 on the front of the pulley under the reinforcing spacer. Some vehicles built from 8/93 through 11/93 had a smaller pulley that prevents the tensioner from operating in range. (Ref. ONP 93B34). Turbo fan clutches should have F3TA-HA stamped on the flat of the clutch nut. If you have an F4TA-HA, replace it with an F3TA-HA. Naturally aspirated should have F2TA-JA stamped on the flat of the clutch nut. NOTE: BIMETAL IS IN THE FRONT COVER NOTCH SO THAT IT IS OPERATIONAL. SYSTEMS WITH INOPERATIONAL BIMETALS ARE OVERSTRESSED.
Check that the belt is fully supported on the routing idler and tensioner idler. Changes in the belt tracking are made by adding crankshaft shims from Shim Kit (F2TZ-6B306-E) to the reinforcing plate to move the belt forward. Replacing the plate with shims moves the belt back as it enters the idler pulley. Ensure fan pulley spacer is mounted in front of the pulley, see Figure 1. NOTE: There is no plate behind the water pumppulley.
Both idler pulleysmay adversely affect belt tracking if symmetrically worn. If the idler pulley diameter is less at one (1) edge than the other, replace it with a new Idler Pulley (YS-216).
To minimize recurrence, replace the belt with a rubber-backed belt (JK6-1118 for the 130 amp generator or JK6-1151-B for the ambulance prep package application
[165A L/N Alt.]).
Check the generator bracket for mis-build. For vehicles with 130 amp generators: the prefix F3TA is visible on the bottom of the generator bracket on F-Seriesvehicles, F3UA is visible on the bottom of the generator bracket on Econoline vehicles. Refer to Figure 2.
F3TA parts are shorter than F3UA parts and rely on a fuel filter
bracketto locate the generator correctly in the sheave. Incorrect combinations result in the belt mistracking at the A/C compressor.
Check the generator bracket for spacers. For vehicles with 165 amp L/N (Ambulance Prep Pkg.): E4TA for F-Series; E4UA for Econoline generator bracket. Additionally, three (3) spacers separate the bracket from the cylinder heador fuel filter bracket. They are the same for both applications.
Replace the spacers if missing. See Figure 2.
A stamped steel sub-bracket attaches in back of the mounting tab at the top of the generator. Verify that it is not in front of the generator mounting tab. Replace the sub-bracket if it was misinstalled.
Verify that the vacuum pump pulley hub is flush with the end of the pump shaft.
cpdenton
Truck needs paint.
Conway AR
Holy old thread there batman. Exactly what I needed though. Leave it to towcat to have the pictures I needed.
Just didn't dig far enough. Thanks for holding my hand!
ironworker40
NYC Ironworker
nj
A little info for anyone that has the open spring design.
That is what I have and I found the Napa ones use a steel pulley others are plastic. Also they can't be reinstalled without re-setting the spring, so anyone that has one of the open spring type take a picture or close look at a new one and note how the spring it pre loaded. It is possible to put it in a vise and re-set the spring to reuse it. Also there is a shim behind the bolt that can be missed or dropped when removing it and if you re assemble the open tensioner without the shim the belt will not line up.
madpogue
Madison, WI USA
The threaded hole spacing on that flange just below the vac pump looks suspiciously similar to the bolt hole spacing on the bracket on the far end of that shock.
got a closed spring design from monument.
is this the super duty design?
madpogue
Madison, WI USA
No, the SD tensioner has two pulleys, one smooth one ribbed. The pivot point is in the center between the two pulleys, which makes for better belt alignment. There's a TSB for retrofitting an SD tensioner to the OBS PSD bracket, but it only applies to the PSD.
