It is a ats 093 model turbo, it's a really good turbo actually one of the better kits. It's a wastegated turbo. As long as you have at least 3 inch exhaust out and keep air filter clean it will do great. Waste gate should be adjustable to increase max boost pressure(of course to make more boost more fuel is required so you can turn the pump up s long as you have guages installed(pyro and boost) guages. Stay at or below 15psi for non studded motor/1200' and below for exhaust temps. However you can bolt a other turbos to that up pipe set up you will have to custom make exhaust and intake to adapt. R and d idi sells a " bolt on" stage 1 turbo that will go in place of your current turbo, and or typ4 on here can do a rebuild of that turbo with a 60-1 intake wheel like I have recently got(amazing performance my opinion). If it come down to it and you wish to remove that turbo for another I would be very interested in your exhaust housing off it! Lol
