Truck is eating Neutral Safety Switches
timlyall
Vista, Ca
I have an '89 F250 C6 w/ Banks first gen turbo.....The one with the big air cleaner box on top of the engine. I have replaced the NSS 4 times in the last 2 years. The first couple of times I thought it was just shoddy Chinese autozone parts. But now I have had two Napa switches die on me as well. The only thing I can think of is, the exhaust pipe routing for the turbo goes right next to the NSS and maybe it is getting too hot and burning something out inside. I have put heat shield around the exhaust pipe right there but can't put heat shield around the switch because the linkage has to be able to move. Yes, I know I can just bypass it, but I have a long driveway that I back up at night and need my reverse lights to work. I have searched high and low to see if anyone else has this problem and can't seem to come up with anything. I know there are a lot of people out there with this setup that run their trucks hotter and harder than me...so...anyone ever heard of this?
chris142
SoCal
The napa switch is prolly Chinese too. Id pull a couple of oe ones off trucks at picapart and see how they do
Do you have stock back-up lights? Some people add more lighting to the back-up circuit and the switch can't handle it. It that's the case, it's relay time.
timlyall
Vista, Ca
I put a service bed on the truck so the back up lights are not stock, but there are only two lights and they are the normal wattage etc. I suppose they were stock whenever my service body was made. Would that make the whole switch burn out though? If that's the case, its possible there could be a short somewhere that is causing over current......but then again its not enough to pop a fuse.
Knuckledragger
Payson, AZ
Does the NSS also run the reverse lights?
I would look to a moving part if the problem is not shown to be heat. The linkage and/or shift arm might be loose or worn, causing excess beating of the switch.
waltynguyen
Staff online
