Truck cranks runs fine till warms up then
Ray-F250
Georgia
my 94 7.3 runs fine cold then it dies like it’s not getting fuel it’ll run ruff and loose power after around 20 miles any thoughts
Oledirtypearl86
Whitehall MT
X2 what drcharles said kinda sounds like with the heat your IP gets heat soaked and won't push the fuel needed
Ray-F250
Georgia
It does turn over a few times before it cranks when it’s warm but will crank it is kinda sluggish trying to crank it
Ray-F250
Georgia
The truck is a turbo as well I was wondering if some how it is getting air in the lines. What would be a good way to determine if it is the ip
Ray-F250
Georgia
Yeah it has no problems cranking. It only has problems after it has been running for about 20 minutes or so then it wants to cut off when I let off the throttle pull over on the side of the road and it cranks back up it does take it a little longer to crank when this occurs though
Ray-F250
Georgia
I have already changed fuel filter and dropped the tank to ensure that there is no blockage on screen
renjaminfrankln
Raleigh NC
Sounds like an internal injection pump issue. As noted earlier a worn out one will act up when its hot.
A leak in the fuel line allowing the pump to suck air would probably happen regardless if it is cold or hot. Before condemning the pump, you should check the fuel pressure at the filter head to make sure the lift pump is doing its job. To my knowledge when they wear out, they are not known for being worse when hot like the IP. But it won't cost you very much to buy/borrow/rent a gauge to test the pressure. Also would have saved you from dropping the tank.
If you have to buy a new IP I recommend getting a rebuilt one from a shop that specializes in IDI's. Search here for vendors. I am in the middle of doing this job for the 2nd time because I cheaped out on a rebuilt IP from pensacola.
Ray-F250
Georgia
Ok thanks what pressure reading should I get when I check the lift pump
david85
Campbell River, B.C.
Throw 1L of transmission fluid in the tank. Better yet, fill the fuel filter with ATF, start if up and let it run for a minute before letting it sit overnight. Then take if for a 1-2 hour drive the next day.
Stalling when the throttle is let off usually is the governor or metering pump sticking inside the injection pump. ATF can sometimes clean this out but you may still be in for a new pump eventually. In my case, I still got a few years out if it.
The_Josh_Bear
Western WA
I had a textbook hot-start IP issue and it never had anything to do with the engine running. I really doubt a running IP getting proper fuel flow would die on itself.
First I would check fuel pressure while running, the IP *will* pull it's own fuel but that's not a good way to make it around town.
Also, make sure your idle RPM is high enough. These are mechanically injected engines, its possible for the idle to be so low the engine won't run when hot, though I haven't heard of it yet.
As @david85 said a sticking metering valve is a semi-common issue with pumps that have sat for a long time. The ATF/Diesel Kleen treatment in the fuel filter works very well in this case.
William88
Staff online
