Tried To Replace Front Brakes... Nope.....
Well I extended myself today and removed the right front wheel only to find the brake pads are fine. Probably have about million miles left on the pads...:D Actually it still had about 1/8 to 3/16 left on the wear cut built into them. It wore me out doing this. I wont be checking the drivers side because it customary wears the same as the passenger side. At least thats what I keep telling myself. Maybe later I will check it for s&g... But its looking more and more like the noise is the rear shoes and those are riveted lining so its just a rivit thats made drum contact. Not a big deal really.
Nope... Don't have air available or that but have 3 impacs ready when I do. I used a snapon 36 inch breaker bar I keep under the rear seat for just such occasions. My surgical altered left arm was doing ok but not nearly what it was back in Nov. Still have a long way to go on that issue.
chris142
SoCal
You dont want a rivit to run on the drum very long. Could be a spring fell out too
Knuckledragger
Payson, AZ
Maybe you should just pick up the truck and shake it, just in case there is a rock or Prius inside the brake drum making noise.
Wyreth
Certifiable Noob
Las Vegas, Nv
Just a suggestion, while back I got one of these: http://www.sears.com/craftsman-c3-1...p-00931305000P?prdNo=3&blockNo=3&blockType=G3
....well for about half that, but still. Makes pick and pull runs and doing things on the side of the road so much easier. Yea it's only 200ftlbs, but if I need more than that, it prolly should be done in my garage anyway.
jrad235
Vancouver, WA
Actually, I made the mistake of only checking one side last year, the driver's side looked great, but I found my pass side wheel bearing was loose this summer, so while taking it apart I discovered that the passenger side brakes were almost gone. A sliver more and it would have been metal on metal. YMMV.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
I have to agree with that...unless you grease the caliper sliding points regularly, it's very possible for one caliper to freeze on the sliders (even with the caliper itself being fine) and grind down one pad on one side, with the other pads being fine. That happened to me a couple of years ago...the other three pads had over 50% of their life left, but one went down to the metal -cuss ...all it was was a caliper frozen on the sliders; replaced the pads and rotors, made sure the calipers were nice and greased ,and I've been fine ever since ;Sweet
Well you guys have made perfect sense about checking the other front side. I had planned doing that anyway but like I posted. I felt the front passenger side was bad by the sound. So I will check the drivers side front but really sure its the drivers side rear that causing the noise. Just feel I can't handle the shoe spring to the backing plate issue with one fairly good hand. Thats attaching spring is a tuff one even with the special tool. Towcat posted the tool some time back and showed how it breaks because of the force needed using it. I really don't want to have this work done for me. Really want to do it myself because I know its done correctly. You all know that drill...
jrad235
Vancouver, WA
I hear you on that. I had a hell of a time with the retaining springs on mine, and I consider myself able-bodied! It's all about having the right tool though.
Sgtbyersfw
