trans temp sensor
fivefish
North Dakota
Going to be adding a tranny temp gauge and have read some threads that discussed damage to the tranny from threading the sensor too deep. Can you all clear this up for me? How do I know when I've threaded to the appropriate depth?
pafixitman
Westminster, MD
Yep you can install it on the side of the tranny >>>> Click Here<<<<< The R4100 is the same as the E4OD some changes made inside but for the most part they are the same tranny. Just keep the temp below 200° F for long periods of time if using this location or in the pan mounting. It's o-k to go above it but not for very long (typically only while backing up a steep grade (say driveway or such) but let her idle till she cools down below 180° F before shutting off (the tranny will continue to "heat soak" for a little bit).
Courtesy of Goat Boy. Worked great for me.
argve
Resident Fruitcake
Gwynneville, Indiana
Most of the senders I have ever seen for measuring fluid don't have an adjustment for depth they just come with one depth fits all - so just slap it in the hole and tighten it down (snug - not cro-magna gorrilla tight - just snug - use tape but don't go overboard because too much will insulate the electrical connection).
deanj
If U have concerns, cut the out let tube and install a "T" . I think the tube is 5/16, so get 2 - 5/16 tube to compression fittings and cut 2" out of the tube.
If you pull the pan down, you should be able to see anything that you would hit. You'll need to keep it low so it stays in the fluid.
Big Bear
