Trannny Swap PSD TO IDI
idiburner
Oconomowoc wi
HEY everyone i am brand new to this site and this is my first post so sorry if i miss anything
anyhow i got a 1992 f250 ext cab long bed 4x4 with the 7.3idi and e40d tranny with 330,000 miles on non-rebuilt tranny and engine:sly
anyhow the other day i was driving and i am pretty sure the tranny decided to go on vacation no matter what gear 1,2,3,4 it woudnt move no matter how high a reved it and in R if i reved it it go super slow. the tranny oil was a horrid burnt smell also. i am by no means a tranny expert but i thing its done.
but i found a 95 psd with a zf5 manual that i can use as a donor truck its a single cab long bed 4x4 but my question is will a direct swap work with some simple modifications??
thanks to you all for your answers
i am pretty sure the first gen powerstrokes use the same block as the idi
Welcome to the forum..Not sure about a direct bolt to bolt swap but its probably not much more than that. You will need to ask about the brake and clutch peddle fit cause there were a few different kinds depending on the years. Caution with the flywheel bolts. Check the length because those bolt holes in the crank flange goes thru the crank into the oily side of the bottom end. They can touch the bearing chamfer. Ask me how i know this. Then the wheel is loose and the bolts are tightly crushing the first thread on the crank bearing. Now try backing them out with ruined end threads.. What a beiotch. Also those bolts needs some thread sealant or the oil will leak past them and really mess up the clutch. torque is 47 lbs.. O use blue loctite cause some have been know to loosen up and shear off. Again not a nice thing.
lindstromjd
Black Sheep
West Des Moines, IA
Bell housing is the same for all 7.3's, from the IDI's to the PSD's. You'll need to use the engine specific stuff for your engine (spacer, flywheel, clutch, etc). None of the PSD stuff will work right for the IDI.
cpdenton
Truck needs paint.
Conway AR
I have a 2wd, so there are some differences there. Here is what i know. You will have to get a clutch set specific to your 92 model engine. Good time to make it new and right anyway. The driveshaft for a 2wd e4od was 8 inches too short for the zf transmission. So driveshaft work will be in order. The from shaft out of the 97 should work in your 92. The transmission itself will bolt right up, and work well. All the pedal assembly, clutch master and slave, will swap right over.
idiburner
Oconomowoc wi
do you know if the clutch well be the only thing i need to buy that's specific to my rig? will i need a different flywheel?, spacer or anything else. thanks for the help
idiburner
Oconomowoc wi
If you get a clutch kit with the solid flywheel it will come with everything, bolts and all.
Aweome thanks for the replys guys. Could my original front driveshaft work with the new tcase or could I keep my original tcase and not get the one one the zf5?
laserjock
Almost there...
I think you will have a length problem but someone else will pipe up.
Howdee and welcome to oilburners, if you miss stuff take a look through the FAQ and TECH section then you will be much more in the KNOW and not miss stuff...as well it will help you make some educated decisions and questions.
Yuppers sounds like a dead transmission for sure...time to replace!
Ok here is as much info as I can give you from my limited knowledge
That transmission will work just fine and bolt directly to your engine, however as mentioned a complete clutch KIT with flywheel and clutch ans TO bearing is needed and specific to the IDI engine.
The clutch master slave assembly will come out as a complete setup and can be used in your truck.
The pedal assembly will come out and can be used in your truck as well.
You WILL NEED NEW NEW drive shafts for this swap to work. Both front and rear, the ZF is shorter than the E4OD and thus your in need of a new shorter front shaft and longer rear one.
Your own transfercase can be used and likely should be to keep things simple in case there are differences in output yoke on the front side. I would imagine if the yokes are the same, that you could use the front driveshaft from the donor truck.
One Caveat is the transfer case shifter linkage, the E4OD is a long bar from shfter to tcase and the PS ZF to tcase will be shorter but not knowing what tcase the PS has I don't know for certain if that bar will work or not. Clearly if you retain the PS ZF/Tcase combo it will work however if you use your tcase I don't know if it will be the correct length. I can measure my linkage bar C to C for the pins and provide you that measurement to confirm it will or will not work if you like.
There will be electrical issues with the differences between the transmissions and such. Basically a reverse light switch and such is what I am referring to and I have no idea yet as to how to deal with that. I'm doing a similar swap myself.
BTW I may be interested in the 95 rear end yoke if it's available? I would have to know what U joint it fits but ya I'd likely be interested in it for sure!
FWI the powerstrokes use none of the same parts as the IDI nothing is interchangeable what so ever.
Again welcome to OB
Al
And ya let me know on that rear diff yoke I'd be very interested in it
idiburner
Oconomowoc wi
clutch kit and flywheel
Do you know of a good and afforidble clutch kit and flywheel that would be good to buy? Just a point in the right direction would be good unless you actually have part numbers that would be helpful. Also could I just get my original rear shaft lengthned and rebalnced or should I just find a donor truck with the shaft since the donor truck I am buying the parts off of is a single cab and I have an ext cab so its shaft already won't work. Thanks for the help.
Nope sorry no part numbers or known good clutch kits, I"m sure someone will chime in with personal exp...Southbend or Valeo are known good brands...for example..
As for rear shaft, this is where it's going to get tricky.
No to lengthening the old shaft, I think you have a two part rear shaft but I do not know for sure.
So without pictures I can't speak to what you should do. Again others can chime in and let us know what is what.
You may be able to get the front shaft if you have a two piece shaft made out of the donor shaft I don't know there are a lot of things in drivelines to consider.
I know what needs to happen, conveying it clearly and consicely is not working right now. I'm going to wait on some that have a SC truck and can tell us whats going on or you post pictures.
JM2CW
Al
MechDiesel
