the avg weight of those bumpers is about 400-500lbs. not only are they used to "push" cars, they are also a counterweight to the loads hanging off the ass end of the truck.
how solid is your front end? if it's got miles, it's a bad idea.Thanks. What's then General consensus, to much for ttb F250?
yours should be a supercab, therefore a d50 front.
if you got all that work done already, then yes, it's not a bad idea to put one on. it's a no brainer as far as intimidation factor is concerned, the problem is the aggressive level goes through the roof with my drivers when they have a pushbumper truck in their possession. i've seen the results when a foreign jobber gets steamrolled by a pushbumpered towtruck. it's very expensive.Yep, supercab/d50. Just did lift kit (springs, shocks, brackets), replaced all steering linkages, & pivot bushings last summer. Was going to remove 1 spring to slightly lower the front end and smooth out the ride a little, but if I do this it should lower it and smooth it out.
Would like a front push bumper, & I think it would work. I am just looking for input if it is worth it. Thanks Towcat and all who might pipe in for your input. Sure would be an easy decision if it was a 350 and/or I had the d60.
nope.I had a local Deputy Sheriff turn left on me when I had a green light and he had no Christmas tree lights or anything tonight. Almost took me out. Kinda wish I had the bumper then, I just might not have slowed down.
We have some very "interesting" local officers. I usually stay sane, but when he almost runs me off the road, the flies down the street almost taking out several other vehicles in the process (all with no lights/warning of any kind), I get a bit ticked off.(I guess this could be a whole new thread.
Edit: thought that I was one of the only night owls out here on the left coast![]()
