Perfect. Thanks.
Good vacuum to VRV and a new modulator so I just need to sort out the in-between.
How much vacuum should be at the modulator at idle?
18-20hg, basically what the vacuum pump puts out. When the VRV is at say 70% of throttle it should drop to 8hg. (+/- 1hg) Ford says to put 1/2” block (.55”) between the IP throttle arm and the full throttle stop. Then set to 8hg, but that does not mean a high mileage IP and tranny shift where you want it. So it’s a way, but really more “gets you in the ballpark.” Then you can rotate the VRV valve.
So if it was me I would take my a/c vacuum pump (You can use a mighty mite hand vac pump, but it’s a pita to keep pumping it.), hook to the vac side of the VRV, then hook your standard gasser vacuum gauge to the other side of the VRV.
1) Check for full vacuum with the gas pedal at idle/rest. (Basically same vacuum reading on both ports. 1-2hg drop is not going to be a issue.) Put the VRV in the middle of its adjustment travel. Loosen the screws a little, move back and forth, set in the middle, tighten the screws. Now start moving the throttle, you need to see the vacuum suddenly drop to 6-9hg when you are say 60-80% full throttle. (It could do it sooner, later, but guessing it is not doing it at all.) If not you need to start adjusting the nut on the VRV till this happens.
2) I am not sure how many turns you can actually turn a VRV before it perhaps bottoms out or the top comes loose. So my recommendation is go up to 3 turns one way, one turn at a time. No results go back to where you started, then go three turns the other way. I think you get what you want to do.
3) You can also loosen the screws and push the VRV all the way towards the window (With a good one this is a late shift) to see if that little extra gets you where you need to be.
If you can’t fix then its bad, look for a used one or try the Nick Pisa one.
If you get it working, likely you can.
1) Now test for proper vacuum down at the modulator. You need to confirm the rubber and steel line is not plugged up or leaking.
2) If you bought a after market modulator most have a adjustment screw in them. (Factory Ford ones did not, I have a factory one, so no expert here.) It’s in the middle of the vacuum plug the vacuum line hooks to. Look to see if flat, philips or hex screw. So after you set the VRV to where you like the shift, you can see if you can fine tune using the modulator screw.
3) Hook everything up and go test drive. Do a couple shifts, pull over, and turn the VRV nut up or down to adjust. Do a couple times and you will get the shift point where you want it.
This is not as difficult as it reads. Feel free to message me with your phone number, I can set up a time to discuss when you are under the hood.
