Timing or Injection Pump?
donald
Unity Or.
Thanks for the explanation i was thinking of using that service for my IP on a rebuilt 92 7.3.
What does a good rebuild cost for a stock pump? or is it better to buy new aftermarket pump?
Thanks
Macrobb
North Idaho
Go check out idiperformance.com
Also, typ4 on here does rebuilds, I believe.
For stock-type power levels, Conestoga Diesel (Mel) is also reliable.
pelky350
Springfield, OR
Well I don't believe there is any "new pumps" out there there are many with quality rebuild and you return your core to them after you change out. Those three above are the top rebuilders with known high quality rebuilds you can't go wrong with. If hurting for cash sometimes used salvage yard or Craigslist pumps are not a bad idea at least to keep moving until you can afford a higher quality rebuild that's what I did. But spending 300$ on a possible disappointment is worth it when a good known quality rebuild isn too much more and known good customer service is well worth it
adamsanders
Virginia
So I picked up a used Injection Pump off Craigslist for 50$. Gonna put it on this weekend probably. I noticed this plate on it though, anyone know how to decode it? Looks like the original manufacturer overhauled it at some point.
adamsanders
Virginia
So I've read many times the 6.9 and 7.3 pumps are interchangeable, do I need to turn the fuel up a flat or so or is it ok as is? Also do you know if Stanadyne still rehauls or the years they did? Just curious on what I've bought.
bbjordan
Snow Monkey
Ashern Manitoba
The 6.9 & 7.3 pumps are interchangeable. Try running it as is before turning up the pump.
The 6.9 pump is capable of melting the pistons on a N/A 7.3!
AFAIK, Stanadyne is still in business. Rebuilt pumps are typically done by authorised Stanadyne dealers.
Jonathanbwata
Weed, CA
Was it the ip the problem...I get blueish white smoke when I drive on a on ramp when I push it to 2500 2800 rpms
I want to hear the ending of the story
