adamsanders
Hello everybody, so I just started to drive my 91 F250 IDI that I just purchased last week. I ran it out of fuel the first time, after that battle I will definitely keep an eye on that. Anyways, It seems to run pretty well but I have encountered a problem. I have read A LOT of threads on this so I feel like I have a pretty good idea of what I'm dealing with. The truck always cranks when cold, although it does take 3-5 seconds even with new GPs. However, after running for about 30-45 minutes I turned it off and it didn't want to start back. It was like it was trying very hard to hit, but just wouldn't. On the second crank it did decide to hit after 6-8 seconds and ran fine all the way home.
So I know a worn out IP would cause this but I believe I also have a potential timing issue and I was wondering if that would cause this. The guy I bought it off of said he had took the IP off and when he went to put it back on, he said he never could see the mark on the cam gear (I know you're not supposed to remove the IP housing anyways). He said he got frustrated and just bolted It back on and it ran. So I would venture to guess my timing is way off. And also the only time I can see any smoke is a blue/grey smoke on hard acceleration. I was thinking a properly timed diesel would put out a little black smoke under hard acceleration.
So in summary, I think I have a timing issue and is there any way to check this without removing the pump housing? I know how to check once off but that does take a while. Or is this definitely a worn out IP? The truck won't be used a ton, so is there any way to make this pump last for ~10,000 more miles if it is a worn out IP?
Thanks
Thanks
