Timing issues
Josh650
USA
Hi I have a 1994 ford f250 with a 7.3 IDI. i bought the truck as a project. it always started hard, seemed to be sluggish and has always smoked a little at idle. I thought it was normal for an old idi (I usually drive a 6.0 powerstoke) until I was towing my equipment trailer with a skid loader and the truck just about stalled going up hill at a slight grade. So i started messing with the timing and I advanced the pump abought an eighth inch and the smoke pretty much went away at idle and it seemed to run a little bit smoother. I then found a Snap On MT480 on marketplace, I bought it and hooked it up to the truck and it was way retarded. I began advancing the pump more and more until I couldn't advance the pump any more. The truck wont start on its own now and is currently 5 degrees retarded according to the timing meter but it sounds like its over advanced (loud diesel knock). Is there a way to verify if the tool is working properly or to verify the injection pump is working properly. Thanks for reading and for any input.
Black dawg
sw mt
8.5 degrees is with a pulse meter.
That style meter I think timing spec is around 2 ATDC....
Josh650
USA
Ok thanks, I’ll retime it one of these days and see how it does.
Josh650
USA
I retimed it to 2ATDC and It runs smoothly and and quietly. I haven't towed anything with it yet but I took it for a test drive and It seems to have ok power. thanks.
dddd
