timing at 11 degrees got questions before I turn it back.
junk
Paullina, IA
Ok I just checked my timing with a Snap on timing adapter like the ferret. Worked fine once I put the timing clamp on the right direction. I came up with my timing being about 11 degrees. So I need to turn that back a little. So I have a couple questions to make this easy on me when I turn it down.
1. Being 11 degrees what am I doing to my engine? Does it cause long term issues or just lack performance or efficiency?
2. What should I set it to? 8.5 or 9.5 degrees? I've read both.
3. Should I turn up the fuel before I change the timing? I was thinking I read that it affects timing. I have an n/a pump on turbo engine.
4. How many thou of movement is a degree of timing? I know Gary has posted this and I'll be darned if I can find it.
Thanks,
Jeremy
Ya I'd suggest 9.5...factory iirc is 8.5
don't change fuel until you have timing dialed in and set.
Who cares how many thou movement to time it, you have a meter USE it! If you need a guesstamate try 1/2 a dimes THICKNESS not width...LOL
Take a center punch and mark the split between the IP tower and the IP set the point in the gap and make a mark before you do any changes...this makes it so you can return to that exact spot by aligning the two half circles.
I'm sure you you search there is a thread on it IP marks for timing purposes or something like that...IIRC
Good luck oh and you can have a negative effect on the GP by too much advance...burning tips etc.
junk
Paullina, IA
Just trying to figure out if it needs to move .06" or .125" or .25". I didn't really want to keep moving it around overshooting the timing. It's cold outside and I'd like to make the changes quickly.
Really its a tuff job to get the degree of timing you want in small amounts. Doing as Al suggests is a good idea. Making a center punch mark in the joint BEFORE you move the pump can apy back dividands. Its easy to match up the half circles of the punch mark. 8.5 plus or minus 2 degrees is a factory setting. So any factory engine could roll down the road with a timing of 6.5 and up to 10.5 advanced from the factory. Thats a big swing to me. I like running 9 to 9.4 advance. I like the sound the engine makes as we drive down the road. I feel like my engine is singing to me a sweet song telling me ... Thank you for making me what I am today...:hail:D:love:
jayro88
Auburn IN
I thought that adjusting the fuel causes you to have to reset the timing? If this was the case it would be less steps to up the fuel and then do the timing.
As far a s timing, mine is set at about 9.3* IIRC. The punch idea is good so you have a reference point.
chris142
SoCal
I just use the scratchawl to mark mine. the amount you need to move it is very very little
Any kind of a mark will work but. I prefer the center punch mark because its easier for me to make a circle punch mark again if I want to back up the timing to wgat it was before I played with it.
TahoeTom
S. Lake Tahoe, CA
Per my Haynes manual 2 degrees of timing is .030" on gear tower. That isn't much if it is correct.
heartfire567
