Can i put a tilt steering in my truck? What is a direct swap?
Do you need to lubricate the ignition actuator? Mine broke and I'm in the process of tearing the column down. The bronco article has the correct part number door my truck and it is a stock item at Ford.
For anyone experiencing excessive travel when turning the ignition key, don't ignore it our you will be stranded. I had to cannibalize a spare switch for the spade connector and wire to get my fss energized.
