This can't be good, suggestions to what's going on?.
notenuftime
Pennsylvania
after hauling some wood today i happen to look down and see this, the top image is my road draft tube with that white gunk coming out. Below image is the dip stick, oil should be black as can be but is a off clear. I'm not eating any coolant and truck runs and sounds fine, any one know what is going on here.
Oledirtypearl86
Whitehall MT
A lot of people switch to electric pumps but a mechanical pump is $35 and all you do is pull the fuel lines take pump out and slide new pump in but make sure the pump lever is under the cam that auctuates it and you might have to bump the motor to get it to sit under the cam so you can bolt the new back to the motor
Studebaker62
