Thinking about selling my system and starting over
NTOLERANCE
I'm the cotton swab
cottage grove, wi
I have an idea for and on board heated wmo system in my new econoline. Ill be picking up the tank for it soon. This means that my current system would have to go. Is $300 a fair price?
110 gallon l shaped bed tank has a welded fitting and valve on the lower corner for a pump to suck from
Pa biodiesel 55gpb centrifiuge
110volt motor, with a belt driven power steering pump
Adjustable regulator with gage. Has multiple preset pressures
HS108
Diesel Newb
Connecticut
Id buy that from you if i was closer. That transfer tank goes for 300+ in my neck of the woods
NTOLERANCE
I'm the cotton swab
cottage grove, wi
I'm curious to know more about your variable hydraulic regulator.
Ancient Chinese secret #1 son.
Its off a forklift carton clamp. ITs not as sensitive as I would like. Lets more through than I would like. I havent hooked it up without a bypass yet. Worried about hurting the fuge.
bleachasaurus
