Thermostat
BigRigTech
Diesel junky
Nova Scotia, Canada
My 97 450 seems to run really low on the temp gauge (I know - factory idiot gauge:rolleyes:)....I have good heat in the cab and it runs fine. For those with a factory idiot gauge where does your temp needle typical rest?....I need to get some Autometers in this thing too. A new t-stat might be a good start as well.;Sweet
Mike
Stroker
Cora
Gosh, if I recall it right my 95 usually ran down around the "N" on normal. If you are going to do a t-stat try the 203° from Dieselsite.
BigRigTech
Diesel junky
Nova Scotia, Canada
The "N" eh....Right were mine runs too....Maybe that's normal. The upper rad hose neck looks recently new so I have to suspect there might be a new t-stat in there.
Mike
Stroker
Cora
The 7.3's have a great cooling system. If anything they run a hair on the cool side with the stock 197° t-stat hence the upgrade to the 203° version. If you overheat a 7.3 you are really screwing up somehow.
FordGuy100
Silverton, OR
Yeah I dont think I've ever really heard of a 7.3 PSD overheating.
foxman
foxman
upatoi, georgia
Foxman's 96 7.3 runs with the nedle centered on the "N" of normal after literally hours of interstate hard driving. Everything same as you mention = good heat, good defrost, everything seems OK so . . . . . I have to think it is the correct temp.
Foxman
lwillson
Saskatoon, Sk
Mine usually sits between N and O. I do know that the water temperature has gone up since installing the intercooler, as well, the water temperature is higher when the A/C is on. There's lots of hot stuff that wants cooling before the rad even gets cool air. I was worried about it, but it doesn't seem to get hotter than normal.
If you have an infrared thermometer, shoot the bottom rad hose or the block once its warmed up, it will give you a reading that is pretty close to the actual water temp. It was the easiest way I found to do it without getting wet :)
Studebaker62
