TODAY I purchased 10 feet of 000 red jacketed battery cable. 10 x 3/8" dia holes 000 ends to be crimped and soldered. 3' of red heat shrink and same of black.
I will be making a custom set of cables for the Big Blue Ox truck for my stud type group 31 batteries.
Lots of pictures and explanations as to why I do what I do. I AM EVEN go8ng to add some of that heat wrap tube stuff from the funky 90 deg elbow on the stock cable; which BTW I will be reusing as well. Think header wrap for wires so a sleeve.
Purchased 3 feet of DEI sleeving and I am guessing that I can seal ends with heat shrink so this should be good.
So far I am into this for 160 bucks or there abouts. I AM sure if you wanted you could find premade sets for less money but doubt it will be exactly what you want.
Southern Interior Truck and Electric had on for 95 bucks...but lead post type not a stud which is what these will be.
I am tired of crap old green frayed cables so expect top shelf stuff for this tech 101.
We have likely all seen a variety of ahem problematic battery cables thus causing issues with batterys draining or not able to charge or hard starts. So for starters....pun not intended her are a couple images of craptastic main battery leads.
This is whats on me Big Blue Ox now...crap and you can see the stud terminal from 1 gr 31
And the other end of same cable.
Another example of excellent care NOT
Here are some of what is needed and 160 bucks worth of cable and ends shrink tube and heat protective tubing. Crimp tool 50/50 Rosin core solder and solder paste. Not seen are professional grade cable cutters and propane torch.
As you can see there are a few ends here
The lowest lug is one of the 10 I bought the other 2 are stock on hand. All 3 are crimp and solderable.
I will get on this as soon as I remove the two grounds and main lead from the Blue Ox hopefully tomorrow.
Thanks for looking
Thanks for looking
