talk me into a turbo
chris142
SoCal
I know that a turbo would wake my truck up some.I've got the timing cranked up and it will smoke under full acceleration so its getting enough fuel. It runs smooth as could be. I came up socals cajon pass (6%grade)@75 mph with a 500 lb atv in the bed and could have gone faster. I don't see a need for a Turbo.
My mpg isn't the greatest but imo that's due to not having an overdrive.
Thoughts?
Wyreth
Certifiable Noob
Las Vegas, Nv
you will smoke less, use less fuel, less throttle, and have more power.
a turbo will make your rig better in every way.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
What was your exhaust gas temperature when you did that?
The core argument for a turbo is that it will give you enough air to burn all of your fuel, and also that you'll have enough air to bring your exhaust gas temperature down compared to what a naturally aspirated engine will run at. Many people believe that a pyrometer's only necessary with a turbocharged engine, but some people have installed pyros in naturally aspirated engines with stock fuel systems and have been surprised at how high the exhaust temp, and therefore the temp inside the cylinders, was at.
If you can keep your foot out of it, a turbo can also help with efficiency...it's essentially free power, taking some of the energy that would otherwise be wasted going out the exhaust and using it to get more air into the engine. Again, if efficiency is your goal, the key is to not modify your fuel system and keep from using more throttle than you would have before (which can be especially difficult the first few weeks after doing the install).
Finally, if you spend a significant amount of time at higher altitudes (e.g. Cajon Pass), the turbo will help counteract the lower air density/pressure.
IMHO it would be a waste of money to go out and buy a brand-new turbo system, and yes, whatever turbo you install will make the engine more complicated...but, if you can get your hands on a complete used turbo setup, it'll give you a net benefit in the long run.
Just my $.02 ;Sweet
redneckaggie
rebel w/o a cause
angleton/stephenville tx
500 lbs is absolutely no test, hell I would be ashamed if my tdi wouldnt tow a 500 lb atv up a grade hooked onto a small trailer at those speeds
cpdenton
Truck needs paint.
Conway AR
If you like the way it runs now.....get a turbo and love the way it runs.
No seriously, go get a turbo.
seawalkersee
It needs a turbo...
KCMO
Okay. So you think all is right in the world with what you have. I was the same way. I installed the blower on mine and with just 6 psi, it is night and day difference. But, with the blower wine, it is just too much. I got the hook up on the turbo and will get that project started in the coming months. 500 lbs is like me driving with 2 of me being passenger. Not really a test. With it NA, I was yanking out trees over at my dads place. When it would hook, you would know it, but it was not really straining the engine. Now with 6 psi, driving it pulling out trees yesterday, one got hooked on a vine and went vertical when I was looking in the mirror. Didnt even idle down. So, imagine what it is going to be like with double digit psi.
Buy the turbo and an overdrive. Never look back.
SWS
kc0stp
30 Hour Famine
Colorado
IMHO (keep in mind only NA experience is when it blew a CAC tube) with a turbo these trucks aren't exactly power houses without one its borderline unsafe to drive in most places and that's coming from someone whos DD is a 100whp Miata
smolkin
Stuck inside Mobile
Mobile, AL
Joining the chorus to add: it's one of those things you have to experience before you'll know how much you need it. I always thought a turbo was just another unnecessary performance mod...until I got one. I can't imagine going back to N/A.
Kinda like how girls used to annoy me as a kid...and then I kissed one...:sly;Sweet
jwalterus
Made in America
Air Force
Garrison, ND
to me it's just something else to break and clutter the engine compartment
keep in mind though, you'll never see the same temperature extremes I do (IE: you'll probably never be changing glowplugs in 30 below), and the land around here is fairly flat
if I moved somewhere warmer, I'd probably go for one though
chris142
SoCal
Forget about the turbo! What's the 20 on the kissing girls?!
bneumann22
