Tach questions
fields_mj
Brazil, Indiana
How does the Tach on a '93 7.3L NA work?
I'm investigating different methods to activate a WI system on my truck. I burn various waste oils and my primairy goal is to help keep things clean. Any increase in performance is an added bonus, but I'm not really wanting to spend more money just to increase my performance since I'm already satisfied with my current performance.
Anyway, Since it's NA, a boost sensor won't work. I've read about guys rigging up a limit switch on the throttle, but that sounds hoaky to me, and knowing the way I treat things, I'd end up breaking it. Looks like there are a few RPM switches out there that could do the job. They are a little more money than I really wanted to spend, but if it's plug and play, and all I have to do is run the wire, then it may be worth it. Problem is I don't know which RPM switches will work with my truck. Most tachs that I've seen are tied into the inition system. Since I don't have a coil, distributor, or spark plugs, I'm pretty sure that's not going to work on my truck. As I look at the different switches, what key words should I be looking for to know that they will work with my system?
Thanks,
Mark
fields_mj
Brazil, Indiana
Well, from the sounds of that thread, getting an RPM switch to work on my diesel is going to be cumbersome, time consuming, and expensive. That's 3 strikes, it's out. :(
Wyreth
Certifiable Noob
Las Vegas, Nv
well it depends, if you're savy with electronics and can spend the time to learn a little C. You could use an arduino micro controller as a tach sensor, and they're like $10-$20. It would be able to sense the diesel tach signal and respond quite easily.
Personally, I think I would want a combination of tach and throttle position. Have the tach sensor enable the system above a certain RPM, but have it fired by the throttle.
Coyote_Red
Chelsea, Mi
From the way I read it all you had to do calibrate the interface for the number of teeth and install a tooth count sensor. If you get the DSL-2 you get the probe and only need to figure out where to install the probe or just use a factory probe in the gear cover.
Coyote_Red
Chelsea, Mi
Interesting, I happen to know a few computer programmers........
jaluhn83
Upper Marlboro, MD
Just do it off throttle - by far the simplest and easiest way to do it.
Don't see any advantage is going off rpm myself - higher rpm doesn't mean higher load which is when you really want water injection as the high temp exhaust gas will superheat the steam. Water injection under closed throttle conditions could actually be detrimental as it'll cool the combustion which is already pretty cold contributing to wet stacking etc. If it's rpm based you'd get this exact condition coasting downhill or up to a stop sign or the like.
The stock system uses a induction sensor that generates an ac signal with a frequency (and voltage, but frequency is what's used for the tach) directly proportional to the rpm of the engine. At idle this signal is ~0.3-0.5 volt and at higher rpm 1-2 volts.
Thus if you're trying to use that signal for anything you need electronics that can interface with a low voltage variable frequency signal. Most late model gassers use something similar for a tach signal, and most electronic speedometers use this, so some sort of speed switch might work, or some types of rpm switch.
Unfortunately converting the signal or any sort of frequency switch would be best done using a mircocontroller, and while this is really not that complex as far as electronics go, it's a project that would require familiarity with basic electronics and design/fabrication/programming.
I've looked into a a converter to run a gasser tach off the idi, but it sort of got sidelined - got to remember to finish that one of these days.
bleachasaurus
Staff online
