T18 / T19 Rear Wheel Drive leaking?
Kingralph88
Johnstown Colorado
What is leaking and how should it be fixed?
Got under after parking today and checked out anything shinny / reflective with a flash light & seen some nice leaky oil?
Clb
Another old truck
nannyfornia
Rear main or the next bolt flange forward, Or it's the speedo drive
ihc1470
Idaho
That looks alot like what an output shaft seal does when they start leaking. Any oil dripping below the driveline after it has sit? What is the oil level like in the transmission?
FrozenMerc
SW Missouri
Most likely the rear seal, although some could be coming from the speed-o drive cable.
The rear seal is an easy repair. Start by dropping the drive shaft, pull the yoke off, and pop the old seal out. Drive in a new one, reinstall the yoke and reconnect the drive shaft. 30 mins tops.
The speedo cable is even easier. Remove the retaining bolt, pull the cable out, replace the o-rings and reinstall.
IDIBOBS
Southern California
Yup. I would do both since they are so easy and cheap. Then clean all the goop and recheck after a few miles. This is basic vehicle maintenance
Black dawg
sw mt
Must be a doug nash od unit?
common to leak around the shift motor, and that style speedo drive.
Make sure it isnt over full, pretty common on add on units to take on oil from stuff they are bolted to.
Kingralph88
Johnstown Colorado
Ill
where would be the best place to buy a new rear seal?, also I am not familiar what the yoke is!
Also are there specifications on o-ring sizes or just match old with new sizes when replacing them for the Speedo cable?
IDIBOBS
Southern California
Ill
Sounds like you’re gonna have to do some research. If your gonna own any truck let alone an old truck yuur gonna have to know some basics or have the money to spend on a mechanic that does.
rreegg
IDI n TDI
Puget Sound
Ill
YouTube for how to. You can get the seal from any parts store - I’ve used Oreilly but prefer Napa. It’s probably not necessary to replace Speedo cable oring - I didn’t. Harbor freight and hardware stores sell oring packs.
I have a strong feeling the black stuff is from u joint grease being thrown during rotation. The fluid that would leak from the seal would be more oily. Check the other u joints on the driveline and see if there’s a similar black spray pattern above.
went through this exact same thing on my truck last year and replaced seal, u joints, etc. every one of the u joints on my truck throws grease in the same pattern. If you deem that’s the case nothing really needs to be done. They should be greased at some service interval..
Just my opinion and have seen very similar things on mine
onetonjohn
California
Just tried "The O-ring store" online for some viton O-rings. Showed up fast, I thought price was fair or cheap (noting to compare them too) and I was very happy with the selection. They even thew some salt water taffy in the box to boot. Customer for life now.
Kingralph88
Johnstown Colorado
Ok sweet thanks all for the info. I have some basics about the 6.9 but I have little to 0 info about t-19 and normal wear items on this trans. I did replace all the oil in the trans maybe 6 months ago and the old looked really good.
I have really cleaned up the O.D and parts on the trans that were really messy. I’ll be able to see where it’s leaking if I let it sit.
Also I have a new problem, sometimes the clutch works and sometimes it just barely does not work, I don’t know the problem yet. The master and slave and line connecting the two were replaced about 2 months ago.. can’t seem to figure this one out quite yet.
rreegg
IDI n TDI
Puget Sound
Possibly needs more bleeding in clutch hydraulics. Pedal a bit spongy/soft? Or maybe pedal lever connection to master pushrod
I agree, you probably still have air in the system.
What OD do you have with the T-19? A Gear vendor?
The T-19 is a tough transmission, have 363K miles on mine.
It is synchored in all 4 gears.
The T-18 I believe has the granny 1st gear, none synchro.
Kingralph88
Johnstown Colorado
I have the Doug Nash OD on the T-19! I have been driving around and the clutch most likely does have air, the connection to the master push rod is 100% with no play, I’m assuming there’s air I can’t get out, I’m going to check connections to my clutch and see if something is leaking air, reason being when I connect my vacuume pump to the master cylinder to pull air out it is slowly loosing pressure. i think there’s could be a leak somewhere in the connections.
I do not see any fluid though so not sure how it’s loosing pressure?
