synthetic vs. conventional grease
typ4
Newberg,OR
I put pink synthetic in my front wheel bearings 7 yrs ago, took a hub off to change a rotor from heat cracking and was prepared to clean and repack, grease was like new, replaced seal and still running it, I can look tolorrow for the brand, I highly recommend it.
Doont get the crappy parts store stuff , I got this from 6states and their 4x4 guy said its the bomb.
this is one of those situations where the Amsoil kool-aid drinkers have something going for them. the wheel bearing grease is some really good stuff. Now where's Javier so his head can swell up bigger? :D
NO_SPRK
User & Abuser
Santa Rosa, Ca
I run synthetic in my car trailer axles because its a little 7k 5lug job. after i switched the usual checkups showed clean grease.
texcl
W. of Cavalier, ND
I went with redline synthetic grease. The only caveat is that it is not compatible with conventional grease so you have to have all the old grease cleaned out (should do that anyway). The old grease looked really good, the rear bearing had a couple of light scratches but not too terrible can tell it's been there for a long time, decided to wait on replacement, I'll service them next fall and have all the parts ready. Really not a hard job, just messy and have to be clean.
typ4
Newberg,OR
Redline is good stuff. And the stuff I use is Hydrotex.
I have used the Redline stuff and like it. What I don't care for is the Chevron grease. That crap seperates and the oil runs out the spring end of my grease gun all down the front of me.... I hate that stuff on my pants and shoes.
redneckaggie
rebel w/o a cause
angleton/stephenville tx
After working with cncs I can promise you that hydrotex and kluber are the best in the business, do some research because they offer several different kinds and grades of each but we have gone as far as nixing the manufactures reccomendations and using hydrotex and kluber on everything in the shop. we use up the surplus mobil and other brands lubing seals for reassembley of various parts.
JunkCowboy
