Switching Pump from C6 to E4OD FIPL
jhenegh
Truck Still Earns its Keep
Deerfield, WI
I haven't taken anything off yet because I didn't want to mess anything up without the right know-how!
Doing an engine swap, putting IN an engine that was mated to a C6, truck has an E4OD, so I need to put the FIPL on in place of the vacuum dodad. Do they just unbolt and swap or is there anything different on the shafts? I assume I'll then be testing for my ~1.1V idle voltage and ~4V WOT voltage?
Thanks
The injection pump has a throttle tab that has to be changed from the e4od pump to the c6 pump. Easy to do when the pump is off the engine. Just remove the fixture the tps bolts to. Then remove the tiny throttle tab alen screws enough to remove the tab. Now make sure that tab is installed correctly on the other pump. With the throttle position at idle you need to see one allen set screw up top and the other one in down towards the front of the pump. Look closely at how that tab is connected to the throttle shaft. Take a pic of it just in case you mess up. If I had a pic of this I would post it but sorry.. No pics. Gandalf had a really nice pic of an injection pump on his truck clearly showing this. It was not a pic designed to show this but it clearly showed it.
gandalf
Senior Member
Air Force
CA &/or Maine
It's a good thing I'm here to back you up, Gary. That's what friends are for, right?
I'll toss in two pictures. One is an IP stand alone, not on the engine. It does not have the tab mounted, but has a pin for mounting, and gives a good idea of what you're dealing with. The second picture is an IP mounted on the engine. This one shows the two set screws with the FIPL/TPS mounted. It's from a different angle, so may need a bit of looking and translation.
jhenegh
Deerfield, WI
Ok so that pin stays in the shaft and the FIPL circle with setscrews goes right on there? Sounds easily doable
Nope.. That pin needs to be removed for the tps and tab to fit correctly but those are the pics I was refering too. Thanks Ken... Your still the man....:thumbsup: Behind the dummy... Sometimes I can be such a dummy. I'm not likeing this getting older. I'm seeing doctors about every wednesday now. Now some of its from industrial injugrys suffered at work many years ago but some is simple like cataracts.. Boy do those have to go. The doctor thats going to remove them told me I will be able to see 20/20 anagin and not need eye glasses any more. I'm not sure I will like that but its something geting used to I guess. I got used to n.p.o. around here so maybe thats going to be just as easy...
I'm looking at Kens pics. One of those set screws needs to be in the hole in the throttle shaft. At this point I'm not sure which it is any more. Also those screws that holds the tab to the pump ar 1/4x20 threads. Please replace those with a hex head bolt. They are much easier to get a 7/16 wrench on.
gandalf
Senior Member
Air Force
CA &/or Maine
Okay, here we go again. I have two more pictures to add to the confusion. These two pictures have the tab mounted on the shaft, and a set screw pointing upward, as we have stated. However, they also have a set screw facing the rear of the engine, rather than the front. Is it possible that the sleeve, which is a part of the tab, has a hole through two sides? I just went out to check my spare IP, the one which we don't talk about, and the shaft, on which the tab sleeve mounts, does has a hole drilled all the way through, in one side of the shaft and out the other. As I looked at that IP, the holes in the shaft were more horizontal than vertical.
I seem to recall in the dark recesses of my mind, that that shaft is spring loaded. How does that enter into the equation when we mount the FIPL/TPS?
The outcome, so far, is that the tab sleeve mounts with a hole pointing upward and another pointing fore and aft.
Anyway, the pictures:
I'm not real sure what happened here, but I seem to have posted three pictures rather than the two I was trying to post. One, the extra one, came out fullsize, while the two new ones are thumbnail. The large one is a repeat from a couple posts above. Mods, feel free to delete that repeat. Thanks.
the reason why stadyne did the hole drillings, is so when you mount the fipl tab, you can only mount it one way if you're paying attention. this is not saying any kludge and make an effort to really screw things up. I've seen it and the guy refused to acknowledge his workaround was to defeat the purpose of a simple one-way solution. I gave up trying as a result and told him what he wanted to hear.......he needed a transmission.....but I refused to sell him one. Now THAT left him scratching his head :D
I've been involved in many businesses over the years. the transmission rebuilding business is the one I invoke "we reserve the right to refuse your business" clause than any other one.
Well Ken what you have posted is what I knew of but wanted to keep under wraps because its confusing. I have seen both types of throttle tabs with the three holes in them. We still need to have the set screw in the top holes and the other set screw in the forward location like is in your other posts. I hope this helps. Those are really nice pics too. Nothing I dislike more than a blurry pic of anything. Its just a waste of time trying to look at a blurred pic.
jhenegh
Deerfield, WI
Here's the pictures from when I did it. One of the set screws for the FIPL tab has a rod to go in the hole that holds the C6 pin so you really can't screw it up. The little pin pushed right out of that hole with channel locks.
Nice pics there. I never knew nor have found a set screw like that in any of my tps tabs. Nice idea too. I think your on the right track now.
JunkCowboy
